Question about DeLonghi DCU61 Coffee Maker
I am trying to replace the coffee grounds backet and stem that goes inside the maker and cannot find the parts, as well as replacement costs.
    Problem Solver:
  • 8 Answers
I do not know how it look likes. Most of them are like long tubes which is set under a bucket filter made of plastic or aluminum, or maybe stainless. I will cost you to buy it from the Company that sells it. (Shipping and Handling) If they do not have Warranty to return it and have it replaced you are on your own. Some stores Like Goodwill they sell broken ones and maybe you can buy the whole thing if it is working, or just the parts. Make sure it fits yours. Some people can fabricate their own tube and filter using stuff.
Posted on Sep 07, 2010
I need a replacement stem for the filter of a west bend 30 cup coffees maker model 3410?
Fixya does not sell replacement stems. Check with a local appliance parts supplier.
Nov 09, 2016 | West Bend Coffee Makers & Espresso...
We cleaned our DCC-1200 cuisinart coffeemaker twice with vinegar and water however, when brewing coffee now it takes almost 45 minutes for the cycle to complete. When it does complete, the pot is half...
I had the same problem and just finished fixing mine. The problem is very likely that you have coffee grounds in the water hoses in the bottom of the unit; this gets worse over time, constricts the flow, and can lead to all sorts of woes. Cuisinart will void the warranty if you open your unit, and they neither sell replacement parts (e.g., hoses) nor provide any guidance on how to fix it (I found this out when I called them today). If your unit is less than 3 years old it is still covered by the warranty and they will send a replacement unit; if it's more than 3 years old you have nothing to lose!
Here are the steps:
  • First, thoroughly clean, scrub, and rinse every part of the coffee maker that you can access. Make sure to remove the black plastic cover inside the top lid (snaps off easily). You'll be disgusted by what you find and there may be oily caked-on sludge inside the cover. You want to get any stray coffee grounds you can.
  • Get a Torx type screwdriver, size T-10 (this looks like a starburst pattern; a hex driver will not work). You can buy a set with different sizes for about $6 at Sears, Lowes, Home Depot, etc.
  • Turn the unit over and you'll see 4 small screws deeply recessed in the bottom; remove each of them. You may want to use a flashlight to locate which holes have screws, as some don't.
  • Pull the bottom cover off, making sure not to lose any screws.
  • You will see 2 rubber hoses, likely orange, each about 6" long. 1 end is attached to the metal heating element and held in place by a clamp; the other end goes into the coffee maker.
  • Remove the end of each hose that goes into the coffee maker by simply reaching in and pulling gently. They should slide off fairly easily. Do NOT try to remove the clamped ends. Trust me--I tried and they are fused to the metal; they shred very easily and won't budge...
  • Pour a little water in the left hose (with both loose ends facing you it's the one on the left). While holding a cup to the right side hose end blow hard into the left hose. Water will squirt out into the cup and you'll almost certainly see some coffee grounds in the water. Repeat this step 4 or 5 times, making sure there are no more grounds.
  • Re-attach the hose ends to the coffee maker, replace the screws.
  • Run 2-3 full pots of plain water through the unit to remove any stray grounds and you're good to go
Mar 07, 2010 | Cuisinart DCC-1200 Coffee Maker
Presto 2811 coffee maker light goes out and stops heating
Contact Presto at contact@gopresto.com or 800-877-0441. Find the 7 digit model number
02811xx and series number xxxx on the bottom of the coffeemaker.
Apr 23, 2009 | Presto 2811 Coffee Maker
Broken part on coffer maker
Replace it with the same sized tubing that you can buy at the Hardware store. just get the length you need they sell it by the foot. DFD
Apr 20, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Dec 27, 2008 | Faberware 10-22 Cup Coffee Urn
Problem machine
Try replacing the O ring in the brew unit part number: NM01.044
Oct 27, 2008 | Saeco Royal Digital Plus Coffee...
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Pump stem for above item
I have one I'll gladly give you if you pay shipping from Illinois. Also any other parts of this coffeepot you may want, you are welcome to.
I'm not sure how you can contact me. If you post a response, I can send you my email address.
Mar 01, 2008 | Salton Melitta MEU45 Stainless Steel -...
WestBend percolator coffee maker 58002 does not circulate hot water
Sounds like the thermostat is weak and turning off at too low of temp.
Mar 08, 2007 | West Bend 43536 Coffee Maker
DeLonghi DCU61 Coffee Maker Logo
118 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
