Question about Electronics - Others
PNY Optima Attache 2gb
Mine somehow got wrtie protected. now I cannot use it. How do I format it or get write protect off it. It happend shortly apfer I purchased it about a year ago when I was messing around on the PNY website and downloaded some update to it.and I have not been able to fix it or use it since.
Jon Harden
  • 18 more comments
  • phillipsappr May 15, 2008
    Not long after purchasing mine, it got write protected! What good is that? I buy it specifically to write to....then it decides not to let me. HELP!
  • CiscoKydd May 21, 2008
    2G Optima Attache turns up write protected for no reason. No Windows utility will fix it. No FDisk utility helped either. What a crock!
  • Anonymous Jun 04, 2008
    I wrote 1 file to it, and now it is write protected. Is there any way to fix this? I cannot format it.
  • ameripolco Jun 21, 2008
    same think , i back-up quick books once then got write protected , so now I can't use it
  • kuhnners Jun 26, 2008
    Same problem the Attache Optima Pro 2 gb just went write protected for no reason please help
  • Anonymous Jul 15, 2008
    i was able to use mine once......damnit
  • vsifans Jul 18, 2008
    I had mine for a year and then all the sudden it went write protected. I contacted the company and I filled out a RMA - don't know what good that will do me but maybe get money back I don't know what to get now, I don't want to get the same thing but because no one can say why or how this happens, I am hesitate to purchase another flash. Maybe get a CD
  • susie4795 Jul 21, 2008
    just purchased - used once only have like 2 pictures on the thing and now it says write protected
  • rtmc Jul 25, 2008
    I tried using my PNY Optima Attache 2G for the first time, and a pop-up states that "The Media is Write Protected". I have not found a fix for this problem on the PNY website. Is there a fix for this, or have I just wasted my money?
  • Anonymous Jul 26, 2008
    I have the same problem I have a file stuck on the drive and now its write protected
  • Bill57 Aug 17, 2008
    I have experienced to same problem -- just went write protected in the middle of a file transfer. Now, I can't use for the reason I brought it. A total waste of time and my money.
  • Anonymous Aug 26, 2008
    I used my PNY 2G memory stick successfully for about 1 month, then for no apparent reason it became write protected. I haven't been able to figure out how to un-write protect it, or re-format it. It is now useless.
  • fernandocruz Aug 29, 2008
  • Anonymous Aug 30, 2008
    This is gay.
  • Anonymous Sep 01, 2008
    Had
  • jchaulklin Sep 01, 2008
    I've had my optima pro attache approx. 2 mos. and now the "write protect" has occurred.
  • Anonymous Sep 02, 2008
    I've had the exact smae problem with the device, mysterious appearance of write protect that disables the use of the device. Cannot add or delete anything to it, cannot reformat or do anything with it. This is one of two that I own, the other one works perfectly fine, so far. have had bot about 3 months, did not try to download new driver or anything ike that. This just happened during a normal save file routine
    BradG
  • tigerman54 Oct 28, 2008
    Same problem here. I can copy from it but cannot write to it. Other one works fine, so far.
  • Anonymous Dec 05, 2008
    I just ran into this today. Last time I wrote a file to this thumb drive was Sep 17, 2008. I tried to use it today and could not write to it. The solution he that suggested the Apacer utility worked. The utility is kind of scary since it prompts you with a dialog that all data on the drive will be lost without much detail. Fortunately, it only deleted the data on the usb thumb drive.
  • MichaelCT Dec 07, 2008
    What they said - write protected message.
This program for another USB flash drive worked for me
(took me two tries for it to work)
http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
http://usa.apacer.com/us/support/downloads.asp
Download type: utility
Product Type: USB Flash drive
Posted on Sep 06, 2008
The low-level format utility was an excellent solution. This one works on USB drives, while other low-level ones do not. In many cases, this problem is caused by failure to use the "Safely Remove USB" tool on your system tray before you remove your flash drive. This is the little green arrow at the bottom of your screen. Even so, Vista many times will simply not release the device no matter what, in which case you should shut down before removing your device.
Posted on Jan 30, 2009
Take a hammer, and pound it to pieces!
Posted on Jul 02, 2008
I have same problem too... i have photos i save from my friends computer now i cannot open and access... i say WTF? any computer usb cannot open it anymore...
what is going on? what waste of MONEY!!!!
Posted on Aug 21, 2008
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Oct 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PNY Optima 2gb SD Card Write-Protection Problem
Ur right it has a physical problem. Try to format it using dos and then give it a try.
Thankyou
Jul 31, 2009 | Electronics - Others
Pny Optima Attache Flash Drive suddenly locked
look for a slider on the flash drive, I had a pny flash drive that had a slider that when enabled would protect the flash drive from accidental erasure or modification of the files.
Jul 27, 2009 | Computers & Internet
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro went to write protected...
You can see the following link
http://www.fixya.com/support/t275843-pny_optima_attache_4g
I'm not sure , if this would work for you, but you can definitely give it a shot . Fixing flash drive problems , the chances are 50-50.
Best of luck
Proton
Apr 05, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro black/amber went to write protected...how do I fix it?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Electronics - Others Logo
2,450 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
