Question about Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail
Motherboard is not booting!!!!!
I'm building a new pc with this Gigabyte motherboard(GA-MA790FX-DQ6). My spec :
AMD Phenom 9850 Black Edition Quad-Core 2.5GHz
THERMALTAKE W0132RU 1000W MODULARIZED ATX CROSSFIRE ATI
New Corsair Dominator 4GB (2GBx2) DDR2 1066 with Fan
Visiontek HD 3870 X2 Oc Edition
Western Digital Raptor® X 150GB/16MB Cache/10,000RPM SATA
thermaltake water cooler bigwater 760i
I connect all the parts and wires and turn on the power the is nothing comes up on my monitor not even a Bios menu! The cpu is running cause it get hots fans are running, there is noise from the harddrive, the water cooler fan is running. But not booting!! I tried it with another basic graphic card which is Radeon HD3650 512mb DDR2 pcie and nothing comes up either. My motherboard Chassis intrusion header does not have a cap on(don't think its the cause) Is it not booting because the
ew Corsair Dominator 4GB (2GBx2) DDR2 1066 ? Does all the fan headers have to be plug in for the mobo to boot? I only have one hard drive and its connected to sata ! Please help!!!!
    President:
  • 2,351 Answers
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
Posted on May 15, 2008
Do I plug in BOTH the 20+4 ATX power connector AND the 8 pin 12V connector on a gigbyte MB (MA790GPT-UD3h)?
Hi
You only need to plug the 20+4 ATX power connector and how about the 8 pin 12V connector? Well that is use only for legacy type of motherboard that use to require it.
Hope it helps..
Thanks for reaching Fixya
Apr 03, 2010 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Long beep with pause continuous when booting up computer
Remove the RAM and reinsert and then reboot. Also same for the keyboard.
Oct 10, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte MB no boot ga-ma790fx-dq6
did you replace the battery on the mainboard if its weak it will not beep
Aug 04, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard GA-MA790FX-DQ6 no monitor
your power supply is too weak to power your video card.
Mar 07, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard not booting
i think memory probelm
please change memory and try it
Jul 22, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Windows Vista
If you are having trouble installing the drivers from the Gigabyte CD, than go to Gigabyte's web site for the GA-M61SME-S2 motherboard & download the Vista driver's you need. The web site has some newer drivers. Click on this link to go to the driver site.
http://tw.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2507
If you are still having trouble. List what is not installing here.
Same for error messages.
Mike
Jun 26, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Case fan runs on standby
Hi neezels, go to page 53 in you're manual. Scroll to the bottom of the page to ( System Smart FAN Control). This is you're case fan. This is why you're system fan is running while in standby.
By enabled you're case fan will still run but adjust it's speed acording to the motherboard temp. Even though you're system may be in standby you're case fan will continue to fun to maintain temp. (Pretty smart noard)!
Mike
Apr 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Mar 17, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Trobleshooting
I had the same issue with my AMD Athlon 3800+ dual core. I found that I wasn't getting enough airflow to keep the system and processor cool. You may want to check the heatsink and fan rating for your processor unless it was sold in a bundle. Also, On AMD's of such power, they tend to run hot if overclocked. Look into, if you haven't already 2 case fans to go along with the processor fans. I recommend a 90mm in front and a 80mm in the rear of the case. If this doesn't help, let me know.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail Logo
315 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
