Question about Husqvarna Designer I
Help! how do i get the cover off the machine?
  • Husqvarna Master
  • 1,388 Answers
This is a rather sophisticated and expensive machine, why do you want to get the cover off ?
May I suggest you take it to a Husky service centre rather than try to do anything yourself without the appropriate training and service manual.......if you phone first and discuss the trouble you face, they may have a solution which does not require "surgery"
Husqvarna will almost certainly offer an online Dealer Locater in your home country.
Posted on Jun 09, 2008
I have a4830c singer machine can you tell me if feed dogs can go down if so how
You can't lower the feed dogs on the Singer 4830C. Instead, you need to cover the feed dogs. This cover plate is part of the standard accessories sold with the machine.
Most Singer sewing machine manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4830 (the C indicates where the machine was made) is http://www.singerco.com/uploads/download/130_4830_4832.pdf . The image of the feed dog cover is on page 7 (part F, described in item 9 of the list). The installation of the cover is shown on page 10.
You can buy a replacement feed dog cover plate here: https://www.singeronline.com/feedcoverplate.html . A number of 4830C accessories and parts are available here: https://www.singeronline.com/4830c.html . Amazon also has the part here: https://www.amazon.com/Singer-Feed-Cover-Plate-313117-P/dp/B002EZS2E0 .
I hope this helps.
Nov 09, 2017 | Singer Sewing Machines
How do I remove the left cover on a phaff 2140. the piece that covers the tension discs.
Don't know this machine but would avoid pulling anything off as screws have a habit of pinging out and never going back. Try pulling a thicker piece of thread or fabric through the tension disks to dislodge whatever is there first
Oct 02, 2015 | PfaFF Sewing Machines
How to replace belt on singer sewing machine?
You will have to remove the cover to do that. Generally, the back cover is removed first, then the front cover. However, I would recommend that you purchase a service manual for your machine; there are several sites that sell service manuals.
Jul 23, 2014 | Singer Sewing Machines
How to Remove front cover of Brother CS-80 sewing machine
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Feb 27, 2014 | Brother CS-80
I have a Janome 5700, the light has burnt out and there is no directions in manual for changing it, I also cannot find the burnt out light. Can you help. Thanks Penny
Most sewing machine lamps are located inside the face cover on the left hand side of your machine. It should pull open as it is hinged at the back and clicks into place when you close it. The lamp will be visible to you when you open your machine. It will either need a bayonet or screw type bulb replacement. You will need to look at the broken bulb in order to see what type your machine needs.
http://www.janome.com/documents/File/ManualFile/MC5200.pdf
If you look at page 4 of this manual, which is similar to your machine, you will see the face cover is part number 11. In the smaller picture below you can make out the hinge on the back of the machine that allows you to open the face cover like a door. Hope this helps!
Sep 03, 2010 | Janome Memory Craft 5700
Brother XL-6562 Mechanical Sewing Machine
Dear jbanistr,
My wife and I just had this same problem (or at least getting the cover off) and have a possible solution. Safety first, unplug your machine from the wall. Next remove all the screws, three by handle, three on the bottom, one on the rear of the sleeve arm, one on the light bulb cover and one inside the lightbulb cover that goes sideways into the frame. I believe that's all of them but look for any that hold plastic-to-plastic or plastic-to-metal. Take note not to change the stich settings or else you'll have to find and set the number wheel and the adjuster to match, not fun. The way we did it was starting from the top, pry the case apart slightly and with a flat screwdriver gently lift the case over the three adjusting wheels so they clear. We then, with difficulty, pried the case the rest of the way open, with a really loud pop! A better way might have been to start pring from the bottom, but it worked. Reassembly was just the reverse, just fit the top first and put all those screws back in.
Hope this helps.
Sep 06, 2008 | Brother XL-6562 Mechanical Sewing Machine
Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email adrianferra@hotmail.com
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
85 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
