Question about Kenmore Washing Machines
Agitator moves slowly and washer will not spin during spin cycle.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Sep 07, 2010
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
The agitator moves very slowly so clothes aren't washed
INSIDE THE AGITATOR IS A PLASTIC GEAR AND SOME DOG EARS WHICH GRAB THE AGITATOR,,,USUALLY ITS THAT,,CALL YOUR LOCAL APPLIANCE PARTS STORE,TELL THEM THE BRAND AND THEY WILL KNOW JUST WHAT YOUR TALKING ABOUT AND YOU NEED,,ITS A SIMPLE FIX,,NO NEED FOR TECHNICIAN,,
Sep 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
41 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
