Question about Seth Thomas St. Thomas Creations 6006.130 Palermo 1-PC Enhanced Height Elongated Toilet
I have a Seth Thomas pendulum shelf clock with 48N on back and two large and one small winding arbors I don't know the proper way to set it
dragonsthatk
  • 547 Answers
SOURCE: I have a Seth Thomas Sonoma chime clock and no instructions
there should be a key to wind in hole in face
Posted on Feb 12, 2009
escapement
  • 2334 Answers
SOURCE: Why is there two places
Two winding arbours are in clocks with chiming, because there are two separategears in one clock and each one is driven by separate mainspring. Description for winding is: Wind each spring as long as you do not feel significant resistance. As soon as you feel the winding goes too hard - stop winding.
Rate me, please.
Posted on Aug 05, 2010
aquaman987
  • 927 Answers
SOURCE: we have a seth thomas
The clock must be levelled the same as when it was previously set up. In other words, if you didn't check the level of the clock before disassembly and reassembled it and re-levelled it, it may not operate because it might not be the same.
Some clocks have different weights for the clock, chime, and hour strike. Did you mark them and install them in the same location?
My Seth Thomas has a screw to adjust the swing of the pendulum to allow proper escapement on the gear, but you have to be able to determine which way the pendulum needs to swing more to make that adjustment. I may be able to help you with this!
You may need a clock repair service.
Let me know,
Gary
Posted on May 29, 2011
reyjoshua07
  • 1157 Answers
SOURCE: i need to know how
Hi ajhazel1,
Please follow the steps below on how to set the alarm on your seth thomas mantel pendulum clock.
1. Determine if your Seth Thomas mantel clock is a 7-day clock or an 8-day clock. On most models it will say right on the face of the clock which type it is. Seven-day clocks must be wound every 7 days, and 8-day clocks must be wound every 8 days. If you are unsure you should wind your clock every seven days.
2. Look on the back of the clock. You will see three large holes (just large enough for the clock winding key to fit into) plus one or two smaller holes (often just large enough for the small end of the key to fit into). The two smaller holes are for speeding up or slowing down the clock and for turning the chimes off and on. The three larger holes are the ones we are interested in--they are the ones we will need to wind every 7 or 8 days. On some models the three winding holes are on the front of the clock. Winding instructions are the same, regardless of where the winding holes are located.
3. Push the large end of your clock winding key gently into the hole on the right as you look at the back of the clock. This hole allows you to wind the 15-minute chimes. Gently turn the key clockwise. Keep turning it until you feel resistance and the key stops turning. Remove the key.
4. Insert the large end of your key gently into the center hole. This hole allow you to wind the main clock mechanism, which allows the clock to run and to keep time. Turn the key clockwise firmly but gently until you feel resistance. When the key no longer wants to turn simply remove it.
5. Insert the large end of the key into the hole on the left. This winds the hour chimes. Turn the key clockwise firmly but gently until you meet with resistance. When the key no longer turns easily remove it and place your clock back on your mantel. Your clock is now set to run for 7 or 8 days, depending on the model you own.
6. Use your hand to start the pendulum swinging once the Seth Thomas mantel clock has been set to the right time. The pendulum should be located in the back of the clock. The clock will not keep time if the pendulum is not moving.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 24, 2011
AndrexT
  • 19719 Answers
SOURCE: How do I adjust pendulum on a Seth Thomas Regina II anniversary clock
http://www.ehow.com/how_12055661_adjust-pendulum-seth-thomas-clock.html
Posted on Aug 18, 2015
What can be done to fix Seth Thomas wall wind clock losing 14 minutes every 24 hours?
I would get it cleaned and reoiled. The reason is that that the oil starts to harden and in turn makes it slow. Since I do not know if it has a pendulum. If it does you might need adjust that as well.
Jun 17, 2017 | The Audio Players & Recorders
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register ยท My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
Us navy seth thomas clock runs slow?
If Hand Wind---Ajust screw device on swing arm clockwise
Mar 19, 2015 | Seth Thomas Audio Players & Recorders
Need to speed up my seth thomas wall mount hand wound clock
Can't Tell From Picture, But If It Has A Pendulem Ajust screw clockwise for faster (screw is last on arm)
Mar 15, 2015 | Seth Thomas Audio Players & Recorders
How do i slow down my 1920 1930 seth thomas matle clock. i tried slowing with the key but it doesnt slow down. it gains about an hour in every 12 hours
I wish I knew the name of the parts but here we go. On the swinging pendulum on your clock there should be a sliding weight on the bar. This will have a set screw or a thumb screw that you can loosen and slide the weight up and down to change the pace of the pendulum. Down is slower and up is faster.
Jan 18, 2015 | Seth Thomas Audio Players & Recorders
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    Why is there two places to wind a Seth Thomas Corsair E537-000 clock? Any description on the proper tension for winding?
    Rate me, please.
    Aug 05, 2010 | Seth Thomas Watches
    I have a Seth Thomas clock that needs started
    If it has a pendulum, you need to either lower the weight or adjust the ticker.
    Dec 26, 2008 | Seth Thomas St. Thomas Creations 6006.130...
    Seth Thomas St. Thomas Creations 6006.130 Palermo 1-PC Enhanced Height Elongated Toilet Logo
    124 people viewed this question
    Top Seth Thomas Home Experts
    Austin
    Tom Chichester
    William Smith
    William Smith
    Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
