Question about Husqvarna Designer I
Designer 1 bobbin assembly loose or broken. will not allow machine to function. trying to take cover off machine to remove bobbin assembly so I can use machine until I can get it to repair.
  • Anonymous May 14, 2008
    Having Problems with my Designer 1 bobbin winder. Put the bobbin on and the winder spool came to bits. I heard sometiing drop down inside. Help!
    Novelist:
  • 192 Answers
If the bobbin winder spindle is loose and flopping around in the opening in the front of the machine is has come out of the frame that it should be mounted in. Operating the machine with loose parts inside can be risky for the machine and the operator.
Don't take a chance on causing further damage to the machine. The bobbin winder can be replaced without too much trouble and is relatively inexpensive.
Posted on Jun 12, 2008
  • radcal Oct 26, 2014
    If the pin is in the center of the winder, great. But, it will come out again sooner each time you put it back. If the pin isn't still in the center of the spindle, and about 40% of the time it is not, it is loose in the machine. You can still remove covers, put it back, use it for a while and then it falls out in the middle of the next big job you have with a time crunch. Fix it right the first time and forget about it.
    New Friend:
The bobbin winder is held in place with a pin. If the "o-ring" on the edge is ok, just take a thin object and push the pin in the center of the bobbin winder back in it's mounting hole (jiggle around to find the mounting hole). Then push a little more to secure it (friction fit). I discovered this after taking both back and front covers off!!!
The "trip" for the bobbin winder has serations on the mounting post, so it can be pulled off and rotated slightly to adjust how full the bobbin gets.
Posted on Jun 07, 2013
    If the pin happens to be in the center, push it back in, but don't push too far or it won't work. About 40% of the time the pin will not be visible in the center of the spindle meaning it is loose inside the machine. Now remember, it will pop out again sooner each time you push it back in until you replace it and you never have time to stop and put it back in during your project. Just fix it right and be done with it. A new bobbin winder for this machine will last longer than the original as long as you get a genuine part from Husqvarna.
    Champion:
  • 243 Answers
I am not sure if I understand your question. You mention the bobbin assembly. This could be interpreted as the bobbin basket in the hook area or as the bobbin winder on the top of the machine. You asked how to take the cover off the machine. If you need to remove the bobbin basket the cover slides off above the bobbin then slide the needle plate forward. You can now remove the U shaped grey retainer and extract the bobbin basket.
If you want to remove the main covers there are #10 torx screws on the back and 4 #25 torx screws on the bottom. Do not remove the inside screws only the corner screws and the ones furthest from the corners. The needle threader needs to be in the lowest position and is held by the needle clamp screw. The bobbin winder needs to be in the low position too. The front and rear housing clam-shell together with hidden clips. The next part is scary you slap the machine in the correct places and the back pops off. I do not recommend trying this at home. It is also important when working inside your machine to wear a ground strap and ground the frame to prevent static electricity from damaging the computer chips. After the rear cover is removed there are 2 more #25 torx screws that hold the front cover on, and another #10 torx near the tension assembly. As stated before you may do more damage trying to work on this without proper training.
Today I repaired 7 sewing machines. as the parts are removed I place them in lettered bins. It saves me lots of time when putting it back together to have the parts sorted and lettered. I bill customers at $50/hour. When someone brings us a machine half apart and a basket of screws it usually costs them more than if I did the work to begin with. We have a term for this we call them basket cases.
Posted on Oct 31, 2014
Machine just locked up, no obvious thread/needle issues, can't find answers in book...safety function on, Help! Someone said take bottom off and look for thread? Only used it a few times, but out of...
Can you turn the hand wheel at all ? If not, something is jammed tight somewhere.
Have you removed the bobbin from the bobbin case and cleaned thoroughly around it, removing all lint, dust, loose thread bits ?
If that does not help, can you try taking apart the shuttle assembly, which the bobbin fits into ?
Sometimes you may get thread wound around in these parts and it causes a jam. Please, observe how the parts of the shuttle assembly fit together so you know how to put it back together. There may be a small lever or pair of levers that must be moved to allow the parts to be pulled out. There aren't many, usually two or three pieces.
It's very useful to snap pics.. of it the way it looks before you touch it, and then each step as you take it apart, so you have a guide to putting it back.
It's also possible a gear is jammed. Most machines allow you to remove the upper casing and bottom casing. You'd have to take out some screws to do this. If anything is jammed between gears that you can see, remove it carefully. If you have to use a tool to pull out something jammed, take care not to damage the gear teeth, as that's a big repair job and often not worth the expense compared to buying another machine, sadly.
Mar 04, 2015 | Brother PC-420
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
The wheel won't turn on my singer sewing machine. And I know it not the motor. Thank you
If not the motor or wheel function - sounds like a threading/tension issue. For simple checks -1. You can try to unscrew the wheel counter-clockwise to remove and check for thread or something impeding the wheel tracking itself. 2. If this is not the case, check the thread has not broken off and tangled inside the front head cover where the threading guides are located. 3. Open bottom cover to check thread is not snagged on bobbin cover.
Feb 26, 2015 | Singer Sewing Machines
How to fix viking designer 1 broken bobbin winder
If you mean the bobbin winder mechanism where the bobbin slips on to the spindle is loose, the pin that holds it in place has come out. It's an easy fix but requires that all the covers be removed. Suggest taking it to an authorized Viking dealer for repair. You can find your local dealer by going to the Viking website - http://www.husqvarnaviking.com/us and click on Locate a Dealer.
Jun 09, 2014 | Husqvarna Viking 1
How to replace bobbin assembly
The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
Jan 11, 2011 | Singer CE-100 Futura Computerized Sewing...
Two problems : 1. I have a Designer 1. When e
Ok,...both problems are probably related to the same componet, your upper thread tension assembly. It has a sensor which sends the message when the thread is broken. It also would be the culprit for looping. There is not much you can do except look for lint or loose threads in the threading paths around the upper thread tension assembly and remove it if you see some. You could try setting the upper tension to larger number to see if it will help but sooner or later it will need to see a tech.
May 05, 2010 | Husqvarna Viking 1
Needle up down moves the embroider
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached.
It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving.
If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Jan 05, 2010 | Husqvarna Designer I
Embroidery hoop gets stuck to the plate and needle breaks
This has happened to me as well. What I usually do is:-
* remove bobbin case and clean out any lint, also under the needle plate, then replace needle plate , bobbin case and the little front cover. replace the bobbin , checking that you have the thread going the correct way.
* replace the needle with a new one of the correct size for the weight of your fabric and the weight of your thread
*remove and rethread the top thread
* check that the stabilizer is of sufficient weight for the density of the design. (You may need to float an extra piece of stabilizer underneath the hoop)
* check also that it is bobbin-fill in your bobbin (it is easy to get it mixed up)
* when stitching out lace, sometimes it helps to hoop the solvy double.
Jan 07, 2009 | Husqvarna Designer I
How can I get the case of my Singer Featherweight II open?
To remove the cover of the Singer model 117 Featherweight II sewing machine:
Referring to the diagram below:
1.Remove the face plate by removing the single screw fastening it to the left end of the chassis.
2.
To make things easier, remove the presser foot (raise the presser foot and release the presser foot from its holder by pressing the black plastic foot release found at the rear of the foot holder, the foot will fall off.)
3.Remove the plastic see-thru slide plate that covers the bobbin. Remove the bobbin, and remove the two screws that secure the needle plate.Lift off the needle plate.Don't mess with the feed dog screws( Look closely at the" bobbin case assembly" and note how it is installed. The black thing you are looking at is the assembly. The chrome thing that looks like a hook is a fixed "bobbin case stop plate" , the case assembly fits under that and is supported by the hook race. Approximately 180 degrees from the fixed stop is a spring stop- note that the bobbin case assembly is free to rotate/ wiggle approximately 1/8" between these two points, and it is seated evenly in the hook race.Remember what you see so you can reinstall it later)Remove the bobbin case assembly with your fingers.
4.Remove the detachable tool case from the front of the machine by sliding it to the left.
5.The face cover is fastened to the chassis with four screws- two on the bottom which also pass through the bottom of the rear cover, one behind the face plate just above the lower thread guide, and one on the front of the machine behind the tool case. Remove the screws on the front and the left end, and loosen the two screws on the bottom ( if you are planning to remove the rear cover go ahead and remove the bottom screws completely.) There is no need to remove the screws that hold the auxiliary leg bar.
6.The screws are out- HOW DO I GET THE COVER OFF!?!
There is a hidden locking tab located just beneath the mylar seal that warns you to disconnect the machine before servicing and to close the cover before operating the machine. It is located just to the right of the needle plate and directly over the seam that separates the front and back covers. Don't remove the seal just slice it with a razor blade or utility knife right along the seam, make sure you cut all the way through the seal.
Working from the needle plate opening, take a medium sized flat-bladed screw driver and slide it under the rear cover just behind the seam (see photo) carefully twist the blade in a manner that both separates and lifts the rear cover off the front cover- it takes quite a bit of force and it will let loose with a loud snap. After the locking tab is loose the front cover is easily separated and lifted off the chassis.
unlocking the case:
a closeup of the tab on the front cover
7.The rear cover is held on by three screws. There is one through the back at the handle recess, and there are two screws accessible from the front after the front cover is removed. Lower the presser foot lever, pull the screws and the rear cover will come off easy. Good luck with your repairs.
Nov 10, 2008 | Singer Featherweight II 117
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Sewing Machines Logo
436 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
