Question about Kenmore Ovens
On the kenmore oven model 911.4742992 - F1 - appears on screen and the oven beeps nonstop
Krazytech
  • 725 Answers
SOURCE: kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Posted on Aug 27, 2007
SOURCE: Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Posted on Feb 03, 2008
SOURCE: kenmore, F1
I ended up having to buy a new oven after having someone come out to try to service the oven. It was a bad control panel and I guess they do not make the parts to fix mine anymore.
Posted on Mar 12, 2008
reg501
  • 413 Answers
SOURCE: F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Posted on Jul 02, 2008
Sea Breeze
  • 4654 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
Apr 22, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
The electric circuit breaker kicked off and when it was reset, we are unable to get anything with the oven to work. the time comes on at 12:00 and then it starts beeping and a f 1 light appears
with kenmore F1 is a power failure in side the clock control
your whole clock will need to be replaced
go to www.appliancepartspros.com
type in your model number and look in the control section
Oct 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven showing F1
kenmore digital stove is clicking when cooking in oven
Apr 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
What does the message F1 mean on my Kenmore range?
This probably means the electronic control board has failed. Can you find another model number on the unit? It may be on a metal plate inside the door. This way I can be sure that I'm looking at the correct fault code table.
Jan 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
hutchipop@yahoo.com
Dec 05, 2008 | Kenmore Ovens
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Kenmore electric oven 337098
While I can't promise results, it sounds similar to a problem I have helped over 1100 other solve. Please go to the following link: http://fp1.centurytel.net/Powerman/Dreaded F7 Problem.pdf Let me know if it works for you. You can email me at hutchipop@yahoo.com
Aug 20, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Ovens Logo
57 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
