Question about Haier XQG50-11 Front Load Washer / Dryer
My washer door is broke a small pin in door is broke
  • 50 Answers
If the pin is broken merely insert a new pin or screw that fits. If the plastic housing is broken you will need to replace the door.
Posted on Sep 07, 2010
On my whirlpool duet washer the little pin in the door (black) that pushes in when shut broke and now my washer wont kick on
Is this pin on the door or the frame? If the frame then you need a new door lock assembly that you replace by peeling back the rubber tub bellow after removing retainer spring.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Handle pin broke
this happened to mine while still under warranty, eventually the repair man brought a small replacement part which took 5 minutes to fix, but not before a previous engineer had ordered a complete new door. you should be able to get the part ordered, and it would be easy to replace yourself. Now my FP oven has broken down again
Aug 19, 2009 | Fisher and Paykel E522BRXFD Stainless...
Kenmore washer 44722 water pumps out no spin. Brake actuator activates ,but motor does not turn on to make tub cylinder spin. Is this a Pump short or maybe control panel problem. Thanks,Ed
Ed,
I had a situation such as this with our washer, in the end I had found that the safety switch had failed open. You'll note on the washer door the small pin thats drops down from it which closes the safety switch when the door is closed (if the pin broke off this would do it too) In my case the switch had failed and would not allow the washer to engage into a spin mode. (first unplug the washer) You can check this switch by removing the wires from the switch and using an ohm meter check the switch for continuitty when closed; I expect you'll need to remove the top of the washer to access this switch. It would be possible to connect the wires together going to this switch bye-passing the switch; if it runs you know the switch had failed. AS this is a safety device do not continue use of the washer untill the switch is replaced.
Good luck,
Tom
Aug 14, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Door lock wont engage
YOU MAY HAVE BROKEN THE BUTTON, A SMALL PIN LIKE PUSH BUTTON THAT PUSHES IN TO LET THE DOOR LOCK KNOW THE DOOR IS SHUT. YOU CAN USUALLY FIND A SMALL DIAMETER OBJECT LIKE WHAT IS IN A RETRACTABLE BALL POINT PEN TO SLIP INTO THE HOLE WHERE THE BROKEN PIN IS AS A TEMPORARY REPLACEMENT AND TO CONFIRM THIS IS ACTUALLY THE PROBLEM. IF IT IS, YOU WILL NEED TO REPLACE THE DOOR LOCK ASSEMBLY FOR PERMANENT REPAIR. DON'T SLAM THE DOOR SHUT BECAUSE THESE PARTS ARE MADE OF PLASTIC AND BREAK EASILY!
Jan 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Bosch 500 Washer - Can't Open the Filter Door
I did it! The trick was to push a small nail into the hole and push in on the filter door while rotating the door...all at the same time. The original problem was the water not draining and the washer displaying code E04. Just like a previous solution stated, there was one knee high sock in the drainage pipe.
Nov 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
Whirlpool door pin location
No, unfortunately the door latch assy. comes as a complete unit. Part# 8182634. This # is for the entire door latch mechanism, not just the pin and lists for ~$45.00. Easy repair... open the door. At the 6 o'clock position of the door seal, begin removing the seal clamp with a small screwdriver by inserting it between the spring and the seal. Then peel the seal back (at the 3 o'clock position) to gain access to the latch assy. Remove the 3 screws holding the latch in place and pull gently out. Remove the wire harness. Install the new latch and rebuild. (make sure you position the seal clamp the same way it came off... the spring at the 6 o'clock position.) Install time= ~15 minutes. Job done! and well worth the 50 bucks!
Aug 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
105 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
