You open the back by pulling upwards on the rewind crank. The rewind crank is on the top of the camera on the left (as you look through the viewfinder) in the center of the knob that sets the film speed. The crank is folded into the knob. DON'T open the back until you have rewound the film. You will have to press a button on the bottom of the camera to release the film before you can rewind.
It will be a lot easier if you can get an experienced person to show you the first time.
Pull the film rewind knob all the way out and the back should pop open.
It's on page 2 of the manual. If you didn't get a manual, you can download one from http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
Hi, The battery does not affect the back cover opening. The back can be opened by lifting up on the film rewind knob but on this model, there is a lock. Lift the rewind knob and at the base of the rewind knob is lifted from, there is a safety lock. You have to move this safety lock and lift the film rewind knob at the same time to open back.
While pushing the lock around the rewind knob counterclockwise with a finger, pull up on the film rewind knob until it clicks. Then pull up a little further until the back pops open.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
After rewinding the film, nudge the little switch between the ISO dial and the rewind crank counterclockwise and lift up on the rewind knob until it catches. Then pull up a bit more and the back should spring open.
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Pull up on the rewind knob to open the back door. put the film canister in, lower the rewind knob and pull enough film leader to attach the film to the takeup spool. close the back cover and advance to counter #1
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
