Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Hi i have a flymo vision compact 330, the bearing at the other end of the belt from the motor is worn badley and needs changed . i can stpip the mowerright down to the bearing but i carnt get the shaft out the bearing or remove the bearing from the plastic housing
Flymo power compact 330
test your actuator. I see this a lot on walker machines
May 17, 2014 | Garden
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
the upper section of the grass collection box is a fill indicator. this indicator shows green and turns red when full. it also triggers a power off switch. it sounds like some debris has caught between the switch and indicator.
with a fine dry small paint brush or cotton bud clean around the switch .
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
My rogerblack compact treadmill ag -11306 has become very loud
1) LUBE THE deck belt, this happen because the lack of maintenance, Maybe your have the deck WORN, and you need replacement
2) Lube the rollers bearing.
3) test the bearing from main motor, need repair.
4) see if there are some loose parts inside.
5) Lube the gear and shaft elevation motor
God bless you
Jul 27, 2012 | Exercise & Fitness
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
Switch for hover mower 300mm 1250w
Hi and welcome to FixYa, I am Kelly.
Can we get a Make and model number please? I am searching for any brand of hover mower that is 1250W at the moment and there are at least 3 different brands:
This is the Flymo manual:
http://www.shop.flymo.co.uk/images/mediator/397/oipl2002_p0201018.pdf
This is the switch for the Flymo Hover mowers:
http://www.espares.co.uk/part/lawnmowers/flymo/turbo-compact-330/p/1116/283/116/402362/1136941/8a-250v-lawnmower-switch.html
This was my best mind reading guess. If this is not your brand then help us help you by responding with a make and model number please.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Garden
No power when switched on.
sounds like the engine isnt getting the power to turn it sorry but flymo mowewrs are a pain to repair as they some times cost more to do than buy a new one
Jul 10, 2010 | Garden
Brush does not spin
I thought my belt went bad....which it did, however there was another issue....The brush was not turning freeley, and would hardley turn at all, which caused my belt to go bad. Apparently, there are sealed bearings in the brush that you can not get to. If your brush will not turn, you can either spend some $$ and get a replacement. I opted to spend some time on mine, and soaked it in some Mr. Clean and water. I then sprayed brake part cleaner into both ends, and re soaked it. I then put some dish soap on either end and freed up the bearings. In between each of the steps I described above, I would try to work it by hand. I have not had a problem since, and saved some $$ too! Good luck and hope you get the same results I did;-)
Nov 08, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Have changed the drive belt on my 330 compact, when i turn on the mower the belt slips off. I have moved the square plastic things to adjust the tension but nothing helps. any ideas please
Check to make sure you have the proper belt. The wrong one could be too long. Also check for a siezed pulley or that the belt is misaligned. Also check that all pulleys are still ligned up properly.
Sep 29, 2009 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
49 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
