Question about JVC Video Cameras
I'm trying to record but when I play back the video, i have several horizontal black bold lines. Its the same result over several tapes. I've tried a cleaner but no results.
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 07, 2010
5 Suggested Answers
Polymorph
  • 21 Answers
SOURCE: Video playback is distorted and has no sound
NEVER EVER CLEAN THE DRUM WITH A Q-TIP! The heads are not encased in epoxy like they are on a cassette deck head. In a video drum, they have a small open space around them -and- they stick out slightly, so a Q-tip can and almost certainly will snag on it, either leaving fibers behind or snapping the fragile and brittle ferrite heads. You want a special chamois VCR/MiniDV head cleaning stick. It is flat and has a piece of smooth chamois bonded to it. Do NOT just buy a car cleaning chamois, that's like buying a paper towel to clean a lens instead of buying a special lens cleaning cloth. Those foam lint-free Q-tip type swabs are NOT good enough for the video drum, either. The foam can still snag on the heads. Otherwise, good info. Cleaning tapes should never be rewound and re-used more than a few times. You should only be playing them 10 seconds at a time, so that's a lot of cleaning. Here is a good link with more info than you probably can absorb: http://www.repairfaq.org/REPAIR/F_vcrfaq9.html
Posted on Feb 16, 2007
SOURCE: sony DCR-PC55E
I also have a dcr-pc55e and i think i might have the same prob , have you tried a firewire card and cable you will have to buy one if your pc has not got one you can get them off of ebay for a few pounds , i have just bought one because i had the same prob , but now the pc will see the video camera and start to take the images from my camera but then it just stops halfway into the tape . If you can get it to go any futher than i can after this please let me know , i have posted my prob on here to , thanks jimmer . You could try give sony a call on 0870 5111 999 or you could give the handycam helpline a call i think they are called pixella on 00800 15 32 48 65 to see if they can help i hope this helps you . jimmer
Posted on Jun 23, 2007
sonysonyman
  • 68 Answers
SOURCE: JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Posted on Nov 20, 2007
Taisha
  • 44 Answers
SOURCE: My JVC GR-D77OU Mini DV
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Posted on Jan 03, 2009
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Help With My Digital Video Camera!
You try it with proper connection using a new or working wire if you have used a vcr to play back.
Play the tape with any other camera.Bcoz your monitor may be fault.
Play the head cleaning tape in the camera, and try
May be the recording head of your camera is clogged
Mar 29, 2008 | Photography
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Video Tape picture shakes horizontally
needs tape path alignment or cleaning done
Jan 15, 2008 | Philips DVDR3320 DVD Recorder/VCR
Horizontal lines in my dv tape
TRY USING ANOTHER PLAYER IT MIGHT B YOUR CAM. TRY A HEAD CLEANER
Dec 16, 2007 | Canon ZR85 Mini DV Digital Camcorder
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
Video Cameras Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
