Question about Dell P2210 Monitor
Dell P2210 menu is locked, how do I unlock it?
You have to hold down the top and bottom buttons at the same time for around 10-15 seconds and it will eventually display an unlock icon and you are back in business..
Posted on Nov 02, 2010
  • 2 more comments
  • Christian Thies Nov 03, 2010
    Had to try it twice consequtevly.
    I.e. first time the screen went all grey, second time after about 5 seconds the "unlock" symbol appeared :)
    Many Thanks!!
  • luis mendez May 19, 2011
    Yessss it works. but I had to press the top and bottom buttons at the sime time for around 30 seconds, then appears a lock open (unlocked). After that I had to turn off and turn on the monitor and all it was ok
  • czill May 20, 2014
    I had to hold the menu button (just above the power button) for 30 seconds. This only worked when the lock symbol stayed on the screen while I held the button down. If the lock symbol went away it would not unlock the monitor.
  • Anonymous Apr 13, 2017
    This would only work when I had a computer connected to the display. If the computer is showing no VGA cable or similar it didn't work. After plugging in a computer the above solution worked.
    New Friend:
Thank you my monitor is p2210t dell I just press the Menu then Okey button to unlocked the monitor. My monitor have 5 buttons, power,menu,OK,arrow down and up.
Posted on Sep 07, 2017
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Call to Our Dell Technical Support Number for Apple Mac Mini 1-800-204-4427 For Instant Resolution of Your Query.
Posted on Apr 13, 2017
Dell p2210 menu locked, is there a fix ?
Check with Dell to see if there is some way of reset the electronics in the monitor. If no, then you are SOL
Aug 25, 2017 | Dell Computers & Internet
Tip
Dell monitor Lock and Unlock instruction
'OSD Lock': Controls user access to adjustments. When 'Yes' (+) is selected, no user adjustments are allowed. All buttons are locked except the menu button.
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds.
May not be applied to ALL Dell.
http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
http://support.dell.com/support/edocs/monitors/SE198WFP/en/setup.htm#Using%20the%20OSD
http://support.dell.com/support/edocs/monitors/3008WFP/en/ug/operate.htm
on Apr 14, 2010 | Computers & Internet
My DELL LCD MONITOR E178FP is locked, when i press menu button, on screen it displays lock symbol
Zaheer khan,
To unlock the monitor controls and get rid of the lock you can press and hold the menu button in for 20 seconds. You can also try the information listed in the link below.
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 28, 2015 | Dell E178FP 17 inch LCD Monitor
Lock icon and menu keeps appearing
Anonymous,
To unlock the monitor controls and get rid of the Lock, press and hold the monitor Menu button for 20 seconds. You can also try this.http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L.
Feb 28, 2015 | Dell E171FP
How do I get P2210 monitor to work with USB with Dell Inspiron 15R that doesn't have a VGA port
The Inspiron 15R should have an HDMI port. You should be able to connect the HDMI to the DVI-D port on the P2210 with a cable like this: http://www.monoprice.com/Product?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2 . Alternatively, you can get an HDMI to Display Port adapter. Connect either cable with the notebook and monitor both off. Then turn on the monitor before turning on the computer. Pressing F1 should send the signal to the monitor. However, if you right click on the desktop (anywhere there isn't a program or icon), you should see some links for DIsplay options. You can use those to select the monitor resolution and whether to use both screens (extended or mirrored) or one at a time.
The most expensive option would be a USB to video adapter, see http://www.startech.com/AV/USB-Video-Adapters/ , or docking station. These come with VGA or other video output ports depending on the model. The USB ports on the monitor are just an integrated hub to plug in an external devices. It doesn't communicate to the display.
I hope this helps.
(The DVI to HDMI cable doesn't supply audio but that doesn't matter in this case. However, you may need to go into the Manage Audio devices control panel and disable sound on the HDMI port. Open the Control Panel (Windows + X in Windows 8 or from the Start Menu with Windows 7). Go to Hardware and Sound and then look for Manage Audio Devices under Sound. In the playback tab, adjust the default audio device by right-clicking on the appropriate device. Then click Apply.)
Jan 25, 2015 | Dell P2210 22 inch Monitor
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
Aug 27, 2014 | Dell P2210 Monitor
What is the 2 answer for unlocking the p2210t moniter menu
All answers are in the User Manual :
http://www.manualmonitor.com/dell-p2210
My Dell Monitor P2210 USB Ports Not working
Do you need a USB cable from one of the USB ports on your computer to a USB port on the monitor?
Feb 04, 2012 | Dell P2210 Monitor
OSD lock icon will not go off
accoreding to the dell support website, it says to do this
FROM DELL:
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
web link: http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm
But this fix DID NOT WORK for me....maybe it will for YOU....good luck.
Jul 19, 2008 | Dell W2300 23 in. HD-Ready LCD Television
LCD Monitor will not switch input selections
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell P2210 Monitor Logo
17,014 people viewed this question
Alun Cox
