Question about Splendide 2100 Vented Washer-Dryer
My dryer is not working properly. do i need a repair person to fix it?
  • 50 Answers
My apologies if this answer does not meet with your approval, but as you do not give any information, it would be impossible for anyone to diagnose the problem, thus calling in a technician would be your best bet.
Posted on Sep 07, 2010
F01 error code
Completely disconnecting the electrical power and then reconnecting it will sometimes reset the board and it will operate properly. If your dryer continues to operate properly, then resetting the control board may have fixed your problem.
If the dryer motor continues to stop working, then you may have a bad control board. A wiring problem or drive motor failure could also prevent the dryer from continuing to run properly. A technician is normally needed to diagnose and repair this type of problem. If the F-01 returns and will not clear, then you will need to replace the control board in the dryer.
Nov 14, 2013 | Whirlpool Dryers
My dryer does not get hot
  1. Considerations
    • A dryer needs the proper voltage to produce the correct amount of heat. If your dryer isn't heating properly, it's possible that the power supply is the problem. Make sure that the dryer is firmly plugged into the outlet, and if you have a circuit breaker or fuse panel, check to make sure that everything is in working order.
    Theories/Speculation
    • Several things affect a dryer's ability to do its job. If an external source isn't causing the problem, then the dryer probably has a faulty part. Possible culprits include a damaged or burned-out heating element, a blown thermal fuse or damaged wiring, all of which will require replacing.
    Warning
    • The San Diego Fire-Rescue Department recommends having your dryer serviced by a professional repair person. If the problem is caused by something within your dryer's mechanism, you could make matters worse by trying to find and fix the problem on your own. With the exception of checking the dryer's external power supply, you should leave troubleshooting to a professional.
RATE THESE AFTER READING
Jan 15, 2013 | Dryers
My dyer does not get hot
  1. Considerations
    Warning
PLEASE RATE THESE SOLUTION
The Dryer is 15 years old . . . whirlpool dryer serial number MD1912702. Last night it was running, drying a load of laundry. It stopped. Now it will not start. the timer works. The power source...
Do not think yet of purchasing new dryer nor calling a service person as this may be a simple problem and you can fix it yourself. You may only need to replace some components as this type of problem is usually caused by a blown thermal fuse which is wired in series with the motor. When it blows, power to the motor is terminated causing the motor not to run. No dryer function works then when the motor cannot run.
The thermal fuse is located on the blower housing along with the cycling thermostat. Disconnect power then access and bypass the thermal fuse. The blower housing is located on the front left bottom of the dryer cabinet for the dryers with lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front
Dryers with lint filter on the top
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate the connection properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced including the cycling thermostat if the dryer starts. NEVER use the dryer with the thermal fuse bypassed due to fire hazards. The thermal fuse and the cycling thermostat costs about $35.
Let us know if the problem is not addressed above or if you need further advice but indicate the exact model number of the machine for further advice.
Feb 19, 2011 | Dryers
No heat in my dryer
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 62802 Electric Dryer
Older dryer just stopped heating. Air still blows
Jun 16, 2009 | Kenmore 64742 Electric Dryer
My dryer will not get hot.
Jun 15, 2009 | Roper RGX4634KQ Gas Dryer
DRYER RUNS BUT NO HEAT
Jun 14, 2009 | KitchenAid KEYS750LQ Electric Dryer
Whirlpool 9200 Dryer not heating
Jun 08, 2009 | Whirlpool LER4634J Electric Dryer
Equator washer/dryer - won't turn on at all
May be the door is not latching properly anymore and the door switch has gone bad. If you need a repair person in your area contact Appliance Desk for the same.
you can find their contact information on their website www.appliancedesk.com
Oct 28, 2008 | Equator EZ 1500 Front Load Washer / Dryer
Splendide 2100 Vented Washer-Dryer Logo
285 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
JP Services
JP Services
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
