Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My refrigerator stops running and everything gets warm. If we hit the top of the fridge, it starts to run. Once it stops, it won't start again until we hit it. Any suggestions?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Thermostat is sticking...change the thermostat...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 12, 2010
Ge fridge side by side on top freezer on bottom won't cool everything melted and went bad. lights still work and sounds like it is running. What could be the problem?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 14, 2011 | Refrigerators
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
heatman101
Aug 31, 2011 | Refrigerators
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 14, 2010 | Samsung Refrigerators
Fridge stops working and warms up for half a day then will cool back off and start working for a day or a few days. When it warms up everything in the freezer defrosts but will then refreeze a day later...
Check your defrost thermostat in your freezer access panel. Your defrost timer could be faulty, Your defrost timers ussually run for 12 hours and defrost runs for 30 minutes. That being said that is why I believe your timer is getting stuck on run and then eventually it finally gets unstuck and goes into defrost. Eventually it will get stuck in one place or another.
Aug 27, 2010 | Frigidaire FRS26H5AS Side by Side...
Fridge not getting cold. Replaced evaporator 1 year ago. all good. 2 weeks ago stopped getting cold again. called approved tech. checked everything and said thermostat was bad. being an electrician, i...
You have a leak in the refrigeration system somewhere...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 16, 2010 | Refrigerators
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Our Beko Fridge Freezer has started to make a rattling noise. When it is turned off it stops and starts again once turned on again. Any thing we can do to fix it?
When it is off, gently shake the frig to see if the rattle is something in the frig hitting togrther. If that is not it it could be the compressor hitting the case inside due to a broken spring on the motor. The only repair for this is replace the compressor. In which case you let it run like that till it quits completely. That can be a very long time. Eric
Aug 10, 2009 | Haier HTQ21JAAWW Top Freezer Refrigerator
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad.
My problem also is that freezer is cold but fridge gets warm. When I turn the whole thing off for a sort time it works again.
How would I know which part needs to be replaced to repair this?
Rod
rodbutler@psci.net
Jul 07, 2008 | Frigidaire FRS3R5EMB Side by Side...
Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes: stuck in defrost (if nothing is running) bad compressor (if fans are still running) freon problem if everything is still running
Jun 28, 2008 | Jenn-Air JCD2389G Side by Side...
Samsung RL36SBMS keeps cutting out, it runs for a few hours the stops and gets warm if i turn it off and on again at the panal at the front it will start working for a while? any ideas?
This is not a full solution, but I'll tell you what I did. Somewhere along the way, something worked.
First, I defrosted for about 48 hours. I turned it on, and the same thing happened, as if it was broken.
I took off the back panel (and also the support for the ice rack) mostly. I got all but the top bit off, so it hinged on the top (I was afraid of breaking the plastic. I checked that there was no ice around. I spun the fan, and wiped the grooves where the air flows (to clean it off a little). I put everything back together. It was tricky making sure the wires on the left did not get caught.
Bizzarrely, having disassembled and reassembled everything, it all started working again as if there was no problem.
Incidentally, the blinking light under the "5" seemed to indicate it was in test mode. I tried to somehow get it out of that by holding down buttons for 8 seconds or so, but that did not seem to work.
If this or something else works for you, please do post, but at least this worked for me, and it is worth a shot before buying a new fridge.
Incidentally, I have read enough to know that I will not buy a Samsung fridge again.
Apr 17, 2008 | Samsung RB1955VQ Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
