Question about GPS
MY screen reads Communication device is not responding
How come I'm getting bullied and I get blocked how is that right from.Facebook
you are getting bullied because you believe that you have to read what is on facebook
the answer is simple
block those sites that are bullying you
ignore any attempts to be friends with people you are not sure off
it is really simple
if you follow the rules
the phone ,ipad ,pc ,laptop is there to serve you
you are not a servant of the communication device so
and contact can wait
you can block, delete and even report continued harassment by others to the communication authority
bullies only succeed if you respond
Aug 30, 2015 | Computers & Internet
Can not log into iTunes each time I try I have to reset new pass word.
sorry to read about your troubles. I have not fully understood, are you only unable to access Itunes or are you having problems with other websites also?
May 27, 2015 | Apple iPad Tablets & eReaders
The screen on my Samsung YP-K3 has become very dim and can hardly read it, can it be fixed
the drivers might need updating
NOTICE: The new Samsung Yp K3 device driver release resolves driver conflicts, improves your computer's stability and restores communication with all devices. The newly released device drivers are a high priority update recommended for all Samsung Yp K3 users
http://driversdownloadnow.com/download.aspx
hope this helps
Sep 25, 2012 | Samsung YP-K3 MP3 Player
Communication error 2 means and requires what steps to correct?
try turning everything off then control then heater and hand held reboot system
Jun 30, 2012 | Goldline Pool & Spa
Xerox workcentre pro 40-communication problem encountered
Some connection is lose. One of the connectors to the main board may be loose. The communication it is taling about is the machine devices are not talking to the main board.
If you just purchased it you can call Xerox and they will send someone free of charge to fix it.
The number is 1-800-821-2797.
Does there happen to be a code coming up with the message? like an 03-888 ot 05-222?
Mar 03, 2010 | Xerox WorkCentre Pro 40 All-In-One Laser...
Communication between device and computer
The first thing I would try is to go to the manufacturers web side and download current USB drivers for you computer and device. Install the driver, reboot your computer and try to connect the device. If that doesn't work please let us know.
Apr 02, 2009 | Garmin Forerunner 305 GPS Receiver
Using as a modem for laptop
You need to download the Communication Manager software from AT&T's Communication Manager website. Instructions from the website:
Download the latest Communication Manager software*Follow the steps below to download your free copy of Communication Manager software. You must have a subscription to an eligible data plan and use a compatible device. If using your handset as a modem, a tethering cable (purchased separately) or Bluetooth® functionality (available in select handset models) is required.
For detailed instructions on configuring Communication Manager with your LaptopConnect device, visit our device support site, select your device model, and follow the on-screen prompts to find detailed instructions on configuring your device for use with LaptopConnect.
  1. If you have an AT&T USBConnect Mercury device, download Communication Manager 6.8.104. If you have any other supported AT&T device, download Communication Manager 6.8.19 (THIS IS THE ONE YOU WANT). We recommend you download the Communication Manager software from an existing wireline internet connection. Wireless usage charges apply for wireless downloads.
  2. Choose "Open" (or "Run") to start the installation.
  3. Follow the on-screen installation wizard. After completing the installation, restart your laptop.
  4. After restarting your laptop, double-click on the "Communication Manager" icon.
  5. Connect your LaptopConnect card or handset to your laptop.
  6. Click "Connect" to connect to the internet wirelessly.
Colin
Sep 30, 2008 | Pantech Duo Smartphone
Cannot download photos, message says software cannot read olympus camera.
Make sure the camera is on and PC is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select OK on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Jul 19, 2008 | Olympus Cameras
Black Berry 7250 not allowing me to scroll or answer calls
Sounds like you need to do a hard reset on the device. Try pulling out the battery while the device is on, leave out for 15 seconds and then put back in.
May 26, 2008 | RIM BlackBerry 7250
GPS Logo
253 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
