Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Missing regisrry info
When i start up my computer it says faled to start the conrool center 2.0 the required registry information is missing plese re install the MFL_pro suite (cc025) how do i get that?
it it on my soft ware?
  • Anonymous May 20, 2008
    Installed MFC-440CN Pro Suite Disc. on our 2nd computer. When I try to print or when I start my computer it tells me that Pro Suite was not installed and to continue. Well, continue what????
  • 667 Answers
Hi sheri - there is a qontrol center three available. This may fix your problem Follow the link below. Click on All, your operating system and rnglish. Just scroll down and you'll see Control Center 3.o. There's a link highlighted for the download and instructios. Follow them. Let me know what happens. If this fixes yor problem PLEASE eate as fixed.If not, DONT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks. Let me know what happens.
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8%7d&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc440cn_all&NRCACHEHINT=NoModifyGuest&prod=mfc440cn_all&reg=us&c=us&lang=en
Jeff
Posted on May 14, 2008
  • 84 Answers
Yes it should be on your software disk. usually when you get a service pack update for windows it causes some registries to disappear...
you can also enter the information about your printer on the webpage listed below and download the software from brother.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc440cn_all
Dvd driver not properly installed in registry
If your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry.
Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry.
If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option.
Click "Yes" to confirm the deletion.
Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again.
Apr 08, 2014 | Panasonic Toughbook CF-W8 12.1-Inch Laptop
I have a Dell Inspiron 1525 stuck in windows boot manager file \windows\system32\config\system status: 0xc000014c info: windows failed to load because the system registry file is missing or corrupt ...
Here's part of an article on how to replace that registry file:
Look in the C:\windows\system32\config\regback\ folder.
There should be copies of the registry files stored inside that folder.
They are backed up periodically and stored in that folder.
If you create a MiniWin, BartPE, or a Linux Live CD, you can start the computer from CD and move the file system to the required folder, C:\windows\system32\config\.
Apr 15, 2013 | Dell Inspiron 1525 Laptop Computer PC...
Acer 6920 missing 2 registry files and can't auto repair or start. Hard drive has only 25 gig space left. Are there some files I can download to repair without wiping the hard drive and starting o
If you have the Vista disk, insert it into the CD Rom player. When it starts it will ask you if you want to repair or install a fresh copy. If you choose repair, it will fix any missing registry files
Jul 28, 2012 | Acer Aspire 6920 Notebook PC
Using Windows 7, Trying to install printer, Brother MFC-240C. When computer starts or restarts Small window reads: Failed to start the ControlCenter. The required registry information is missing. Please...
After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
1) Uninstal the suite/drivers, then restart your computer.
2) Reinstall the suite/drivers and restart your computer once again.
3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
Should be either
C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
Information source:
http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
Mar 28, 2011 | Office Equipment & Supplies
The error "CC025" appears [DCP-115C]
first uninstall the MFL Pro Suite & all the componants, shut down and restart system fresh install MFL Pro Suite fro the original CD supplied.
Jul 02, 2009 | Office Equipment & Supplies
I'm using a Brother MFC-5440CN printer-Scanner-Fax. Whenever I clean my registry using various cleaning tools (JV16, Advanced System Care 3, etc.)' the cleaning application deletes one of my printer's...
What you can do is check the registery before you do the cleaning, and compare with afterwards. The registery keys associated with ControlCenter is found in HKEY_LOCAL_MACHINE\Software\Brother\ControlCenter and in HKEY_CURRENT_USER\Software\Brother\ControlCenter
Try taking a screenshot of the keys extracted, or export them, to easier see what's being removed.
Jun 03, 2009 | Office Equipment & Supplies
Printer doesnt install correctly
Did you download the vista drivers or the xp drivers?
Info for vista drivers:
http://www.brother.com/E-ftp/windowsvista/us.html
download the drivers here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=dcp130c_all
check the update for control center, too.
Oct 12, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
170 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
