I am hooking the system to a yamaha stereo receiver and i need to know what jacks to hook it to out or in 3 wire or just 2 because of no video just audio red white yellow the stereo reciever just has aux and phono is it compatible? i got sound once on a dvd music concert that was dolby digital but i am getting no sound at all with numerous dvd
  • 35 Answers
Let me write some basic things about audio and video signals and cables. Stereo audio has two channels, left and right, usually red and white (or black) jacks. You plug in audio cables. Video signals in old receivers are marked in yellow. If your receiver does not have video (yellow) input, usually located above the two audio inputs, you will not be able to watch any video signal through the receiver. The receiver will only play the sound of dvd, since its left and right audio channels are properly connected. Just aux and phono inputs are not enough. Hope this may help.
Posted on Sep 08, 2010
How to hook up speakers
Dennis, Check the attached links diagrams,instruction and guides for hooking up speakers. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Stereo System Stereo Barn
How to Set Up Your Speakers with Receiver or Amplifier
amplifier wiring diagram Google Search
speaker wiring diagram Google Search
Aug 16, 2016 | Kenwood Audio Players & Recorders
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
HOW CAN I HOOK UP MY IPOD TO MY RECEIVER
Use a phono to RCA stereo jack (pic below) and hook one end to the head phone jack on your ipod and the other ends to your amplifier aux or tape input and adjust the volume to low on the ipod - select the input on the stereo - Aux or tape in.
You'll need this type of cable
Nov 13, 2009 | Technics SA-EX500 Receiver
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Bose 3-2-1 to a computer?
If I understand the question right are you trying to hear sound from your computer through your bose system? If you are then you need to hook a 1/8 mm headphone jack style cable on one end to the headphone jack on computer and on the other end of the cable you need a standard red and white rca type connection that hooks to back of bose system for sound. This cable is called a mini to rca stereo cable the pin connection for the computer has 2 little black bands around the plug there are 2 bands for 2 channel stereo sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 27, 2008 | Bose 3·2·1 II System
Zone2 problem
I had the same problem.  Yamaha's web-site states that the zone 2 and zone 3 can only be driven from analog inputs (RCA stereo input jacks), not digital inputs.  If your media center is hooked up with digital connections (such as HDMI), it will not feed the zone 2 or 3.  Yamaha's web-site suggest hooking up both analog and digital feeds.  It claims that the digital will drive the main zone and the analog will drive the other zones.
Good luck...
May 25, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
VCR upconversion
check the wires, they could be bad. Or maybe your vcr head needs to be cleaned
Dec 26, 2005 | Yamaha HTR-5860 Receiver
54 people viewed this question
 Grubhead
Grubhead
