Question about Kenmore 16632 Built-in Dishwasher
The standard procedure to start the machine is to select a cycle (normal, dry heat, etc) then press the start key. Currently when I select the cycle and the cycle LED is on, pressing the start key does not start the machine. I can press cancel, then start and then choose the cycle and it will work. Also, if I first press the start key, the machine will start and the previous wash cycle selection LED will light up and that cycle will run. Do I have a problem with the keypad or the control board or can it be reset?
5 Suggested Answers
SOURCE: Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Posted on Apr 08, 2007
  • 530 Answers
SOURCE: Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Posted on Jan 06, 2009
  • 1632 Answers
SOURCE: My Kenmore ULTRA WASH dishwasher model #1603* does not respond
replace timer/program module Vitally
Posted on May 18, 2009
my kenmore ultra wash #665 - the start is delayed and does not pump water????
Posted on Aug 28, 2009
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
F13814978
Try this diagnostic cycle operation to reset.
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 14, 2014 | Whirlpool 24 in. GU3200XTP Built-in...
Precor treadmill password default setting
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Nov 04, 2013 | Exercise & Fitness
Electrolux dishwasher in locked mode
Good Afternoon David - When the light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, you may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. The dishwasher should resume to normal operations.
Jun 24, 2013 | Electrolux Dishwashers
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
I have a Whirlpool Quiet Partner II dishwasher and it is stuck in the clean mode the light continuous blinks
THat means that something is wrong with the water temp. It is either not hot enough when it fills or the heating element that increases the temp it bad. To start the Service Diagnostics Cycle, press the
Feb 22, 2013 | Dishwashers
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
My dryer will spin and then stop spining reading err68 or err4a what can this mean.
E4A = The drying time has exceeded program time for cycle. Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for any thing that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closetwith solid door, or bad connection in moisture sensor bar cir cuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
68 = One of the keys (buttons) is stuck closed (active). Enter function testmode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control
Dec 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
I have a kitchaid dishwasher model KUDP02FR. When I press normal wash and heated dry, then start, the green light keeps flashing and will not start. Any suggestions? I had a repair man here in August for...
There are a couple of possible ways to reset the board. Pressing the keys HEATED DRY - NORMAL - HEATED DRY - NORMAL. I forget how many times, but all the lights should come on and it will do a diagnostic cycle.
It may work with the HI TEMP SCRUB, ENERGY SAVER DRY, HI TEMP SCRUB, ENERGY SAVER DRY keys depending on the machine.
I don't remember if the door is closed or open when entering the sequence. Try both.
Mar 27, 2017 | KitchenAid 24 in. KUDP02FRSS Stainless...
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16632 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
