Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Wont go from wash to rinse cycle - Kenmore 3.2 cu. ft. Plus Top Load Washer
  • 15,935 Answers
The timer needs to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Gets stock in rinse cycle
Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
Feb 18, 2015 | Washing Machines
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Kenmore 70 series wahing machine wont start rinse cycle
Have you tried the rinse cycle in every wash cycle selection on the dial. Some times after using one particular dial setting all the time the contacts on the switch get corroded or burnt out, if the rinse cycle works in other settings on the dial then this is most likely the problem. You can then look up on line and order a new switch for the unit usually takes about two weeks to get in and is fairly easy to replace.
Aug 26, 2012 | Whirlpool Washing Machines
The spin cycle wont start as the rinse cycle finishes i here two clicks 1 to 2secconds appart and then nothing
Not sure which model you have, but if it spins after the wash cycle, and not after the rinse cycle, it is more than likely the timer.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
