Question about Lowrance LMS-330C GPS Receiver
Gps module not responding
I cannot get the gps signal to come up. what would be the most likely reason. i have two locations for the unit but neither will come up
  • Anonymous May 17, 2008
    cannot get the gps to initialize.get two different messages. the unit is a lms 330 c sn 101186342 had a lgc-2000 sn 11567159 that i thought was bad because it was not responding so bought a new lgc-2000 sn 101762986 but now the unit says waiting for nmea serial data
I found that it was the gold maps in the mmc card reader. Remove card and see if it fires up. Also i can be the 60 ohm resister on the NMEA 2000 y cable
Posted on May 16, 2008
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Poor gps signal outside, just started for no reason, what can i do?
Question--did you move the gps to a different location on the dash or in the car? GPS units need a clear line of sight this means that things like wiper blades or being to high in your windshield can block the signal off. Best position for a gps is 3- 4 inches above the dash and in your direct line of sight. Be aware though that fog, smog, and other weather patterns as well can interfere with a signal from gps satellites. Hope this helps.
Apr 26, 2010 | Tomtom ONE GPS Receiver
TT One can't locate a signal
Hello mate try resetting your unit
Dec 31, 2009 | Tomtom ONE GPS Receiver
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Delay in gps signal
Try taking it outside away from buildings, the unit needs to have a clear view of the sky. If it is in a car then you may need an external antenna,
Sep 14, 2007 | Tomtom GO 910 GPS Receiver
Gps not working
I know this may sound funny but replace the water temperature sensor cable that's connected to the unit. There is a module in the temperature sensor cable that has been going bad on a lot of these units recently. I had the same problem and replaced the temperature sensor cable and that fixed the problem.
Jun 01, 2007 | Lowrance LMS-337CDF GPS Receiver
Lowrance LMS-330C GPS Receiver Logo
361 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
