Question about Maxell Radio Communications
I can't Turn on my Maxell Bt-15 headset - Maxell Radio Communications
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    I can't connect my bt-15k2 to my LG phone
    Hi desireeveiga,
    I see that you need assistance in getting your BT heatset to your LG phone.
    make sure that the BT headset is set to discoverable mode, I believe there is a connect button on the headset that you can press and hold down for a couple of seconds this should lit up a light meaning that the BT headset is ready to be discovered by a device.
    Once the Headset is set to be discoverable you can try and get you LG phone to detect the headset, Once detected the pairing code should be standard try 0000 this should get the BT headset connected to you LG phone.
    I hope that this can help.
    Have a nice day,
    mvincentc
    May 31, 2011 | Just Wireless Bluetooth Headset Wireless...
    How to pair a motorola hs8501226b to an i phone
    Turn on BT on the iPhone. From the home screen: Settings > General > Bluetooth. Setup the headset to be discoverable (push and hold the button on the HS700 until the ring turns blue. Extend the boom mic. I believe you do the same on the HS850.) iPhone finds the headset. Enter the code for the headset. Mine was 0000. I believe that's universal for Motorola BT headsets
    Hope this was helpful
    Positive Feedback ALWAYS Appreciated :)
    Mar 04, 2011 | Motorola Mobility HS850 Consumer Headset
    I have a jabra BT 2035 bluetooth headset.I have lost the phone it was paired with.Please advise how I can pair it with another phone
    Long press on the headset button for 15 sec long and you will be able to pair it again with any other device
    Aug 29, 2010 | Jabra Bluetooth Headset with Adjustable...
    Bluetooth setup
    You need to pair your phone with your bluetooth headset.
    1. Turn on your phone's bluetooth and search for bluetooth devices.
    2. While the phoneis searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the phone finds it.
    3. Pair the devices and allow the BT headset to connect automatically.
    4. To connect, press and hold call/end button on BT headset like the one in step 2.
    Nov 11, 2009 | Radio Communications
    I need to put my samsung bluetooth (wep 301) in discoverable mode
    Whenever you connect your bluetooth (BT) headset to a BT device:
    1. Set the BT device to search for other devices.
    2. While the BT device is searching and the BT headset is off, press and hold the call/end button on the BT headset until it's light is constantly lit and the BT device finds it.
    3. Enter passkey 0000 when asked.
    Nov 07, 2009 | Samsung WEP301 Bluetooth Headset
    Its a maxell mpcc6 webcam with headset an noone
    mi`am cumparat web cam maxell MPCC-6 si nu se vede clar,webu nu are nimik e nou noutz, ce sa aiba ? a fost si destul de scump.si am nvoie mare de el maine..pls ajutati`ma
    Jul 23, 2009 | Altec Lansing AHS-502 Headset
    Hi. Can my SBH500 BT Headset pair/connect to a PC? I have tried but the computer doesn't seem to 'find' the headset
    Make sure the headset is put in pairing mode, to do this, turn the headset off, hold the phone button(big silver round one on the right speaker), then turn the headset on. Hold the button until the blue light goes solid. At this point, your computer should be able to detect it. Be aware, though, that support for bluetooth audio on computers is weak at best.
    Jul 11, 2009 | Samsung SBH500 BT Stereo Headphones...
    Unable to Detect the Jabra BT125 headset from any Bluetooth Device
    If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
    Feb 21, 2008 | Jabra BT125 Headset
    Radio Communications Logo
    75 people viewed this question
    Top Maxell Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Maxell Radio Communication Expert? Answer questions, earn points and help others
