Question about HP Deskjet d1530 InkJet Printer
My HP Deskjet F 4480 has started printing with a shadow gray image slightly below the normal print
  • 385 Answers
Sounds like the alignment is off. try alignment adjustment from the utilities options
Posted on Sep 07, 2010
Testimonial: "Thanks!"
PRINTED IMAGES SLIGHTLY OUT OF FOCUS SINCE CHANGING PRINT CARTRIDGES
Most printers have a "UTILITY" program that will let you align the print heads. I would start there to correct the problem.
Sep 22, 2014 | HP Deskjet 3052A Wireless e-All-in-One...
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
Black is printing gray
Has your printer defaulted to 'draft' printing? That's where grey printing seems to come from.
Feb 20, 2010 | HP DeskJet 9800 InkJet Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Oct 18, 2008 | HP Deskjet 3845 InkJet Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
HP Deskjet d1530 InkJet Printer Logo
792 people viewed this question
Seeker5211
Seeker5211
