Question about Quantaray QB-6550D for Minolta TTL Flash
Resolve error code 2840 in konica minolta 6501 problem:
Bizbub 6501 error code c2823
check the cyan drum potenial sensor located behind the (remove the drum) or the charge wire unit for the cyan drum is loose not properly installed
Jan 05, 2016 | Konica Minolta Office Equipment & Supplies
Error code 6508
Could not find a Error code c-6508. But I did find a paper jam 65-08. Check you document feeder there is a jam paper or sensor problem (PS302).
Mar 23, 2015 | Konica Minolta Bizhub C 6501 Color...
Konica minolta 6501 yellow pictures
Check the yellow drum and also check the yellow developing unit.
Aug 07, 2014 | Konica Minolta Bizhub C 6501 Color...
Yellow hues
Check the yellow drum and or the yellow developing unit
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!!
Jul 03, 2014 | Konica Minolta Bizhub C 6501 Color...
Error code c2863
Hi, i have a konica minolta c6500, and i have a problem with error code c-6500. What happen?
Mar 26, 2013 | Konica Minolta bizhub Office Equipment &...
6500 konica minolta biz pro error code 2840
Konica 6500./6501/5500/5501/6000 printer 2840 problem/error
Solution...this problem is due to color correction unit PGC Sensor. While reading the maximum density this problem has occurred. This centre sensor is also called Gamage sensor.
It is situated at the top left side opposite to Image transfer belt unit for reading the patches as well as maximum density.
The problem is due to dust or toner scattering in these 3 sensors.take out the unit thorowly clean all the three sensors including the contact sockets.
Ensure that all the three shutters are opening properly for all the three sensors.
The centre PGC Sensor is covered with two white tabs.please gently remove them and remove the toner by cleaning.there are chances for toner accumulation under these white plastic tabs.
After cleaning all sensors fix it and do auto Gama adjustment.and color registration adjustment.
PGC and other left and right sensors of the color registration/correction unit also gives 45-20error most of the time either due to dust or due to non opening of the shutters
Jun 11, 2012 | Office Equipment & Supplies
Konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
May 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Quantaray QB-6550D for Minolta TTL Flash Logo
255 people viewed this question
Top Quantaray Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
