Question about Newpoint (200897) (DHN200897) UPS System
Need new battery for Newpoint 200869 - Newpoint (200897) (DHN200897) UPS System
Does the power switch supposed to be on in a newpoint surge protector S75t?
Yes. Otherwise it will not release power to the outlets.
I looked for the specific manual for your surge protector, but I was only able to find one for another Newpoint model (RX50TA). These are all pretty much the same from one brand or model to the next so the information should be sufficient to backup my assertion here. You will find a line on page 2 that states power will not be supplied to the outlets when the power to the surge protector is off. Surge protectors automatically turn off (or trip) to protect your equipment.
Newpoint RX50TA Operating Manual Page 2
Sep 03, 2014 | Computers & Internet
AVR always kinking off.
This means that the power is not a constant, stable 120 V. There is something going on with your power infrastructure that is causing the voltage to fluctuate enough to set off the AVR trim.
Feb 28, 2011 | Newpoint (209180) UPS System
Battery Back Up receptacles no longer work
Your battery is either disconnected or failed and must be replaced.
Apr 06, 2010 | Newpoint (200897) (DHN200897) UPS System
How can i get the electrical service map for 200897 surge protector
THANKS FOR YOU PROFESSIONALISM BUT ALREADY WE SOLVE THE PROBLEM THANKS
Nov 11, 2009 | Newpoint (200877) UPS System
The battery backup is beeping intermittently, but the power is not fluctuating. Does the battery backup require a new battery???
If it's more than 3-4 years old chances are the batteries need replacement. Typical lifespans are 3-5 years on most batteries.
Oct 13, 2009 | Newpoint (200897) (DHN200897) UPS System
Newpoint battery backup
check whether the batterries are ok, if  yes check whether the system is charging.
Aug 19, 2008 | Newpoint (200897) (DHN200897) UPS System
No back-up
YOur UPs is defective. Check the battery. DId you connect it when you first set it up?
Hope this helps.
Oct 21, 2007 | Newpoint (200897) (DHN200897) UPS System
Newpoint (200897) (DHN200897) UPS System Logo
88 people viewed this question
Top Newpoint Computers & Internet Experts
David Payne
David Payne
Are you a Newpoint Computer and Internet Expert? Answer questions, earn points and help others
