SOURCE: graco metrolite stroller and carseat instructions
The car seat should go in with baby facing you or you could try this website.. Hope this helps..
www.gracobaby.com/customerservice/productinstructions/...
SOURCE: adapter for maxi cosi on quinny stroller
Hi there, I've just had the same problem with a freestyle 3 xl (having lost the adapters for the dreami carrycot & maxi cosi car seat). I have been able to purchase adapters at £11 plus £3.99 postage & packaging from the Quinny UK stockists: Dorel Group UK - Telephone 020 8236 0707 Alternatively if you are not in the UK look at www.quinny.com and you should be able to find your nearest stockist. Hope that helps.
SOURCE: How Do You Assemble The Carseat To The Stroller.
You need to remove the food/drink tray from the front of the stroller and then the carseat should fit right over where the tray once was- it will click down and stay secure just like it clicks when attached right into the base for the car. To take the car seat off- you simply take it off the same way as you take it off the base in the car!
SOURCE: Remove carseat from stroller
hia, there is a pull up button on the back of the car seat that will release the chsir from the pram.
