Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I tighten the chain for model 136? - Husqvarna "Chain Saw - 16" Bar, 3 Hp
    President:
  • 2,220 Answers
A link to a 2003 Husqvarna 136 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_O0301010.pdf
See pages 7 and 8 for chain adjustment installation/adjustment.
All Husqvarna saws may be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Sep 07, 2010
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Chain oil leakage
To help you more please give us the model of your Husqvarna machine.
Feb 09, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
I have a Husqvarna 136 / 141 model chainsaw - it has been idle for several months. After starting and allowing to warm up for a minute or two and then attempting to use it - when applying full throtle the...
Has the chain stuck to the bar.? Chain oil has a tendancy to turn to a gluey state when say for some time. Is the chain brake fully releasing.?
Aug 29, 2011 | Husqvarna Garden
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi,have a problem with my 136 chain saw.It cutout with no spark,have checked out cutout switch,plug,it seems to point to the ht coil. husqvarna model 136 thankyou
This checks everything Robert, a shorted wire or defective switch is much less expensive than the coil. I also recommend a new plug for the same reason. The IPL I referenced said pn 530 03 91-43; widely available about $40 and shipping. Try your local Husky dealer (no shipping).
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
HusqvarnaUSA.com
06 1500198
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Husqvarna Garden
Manual for Efco FL6 Chain Sharpener
The chain saw chain sharpener is an "efco Industries" chain sharpener that was made in Italy. Type # 136 & LR# 36941 have a good day please rate bama46, thanks
Aug 22, 2009 | Garden
Need parts for WEN model 6014 chain saw
there are none realy take the two nuts lose take a flate head tighten the chain now if you can pull the chain easy around the bar you good this will give you about a 1/8 in sage on the chain...Good luck
Aug 16, 2009 | Electric Chainsaw Sharpener
How do you loosen the chain on a chainsaw husqvarna 136?
Hi there. On the outer bar cover near the motor you will find 2 nuts. Slightly loosen those two nuts. Then check around the these nuts or near where the bar attaches to the powerrhead at the front of the saw. You should find an adjustment screw of some sort, which will be the chain tensioning screw (which moves the bar forward/back depending on which way it is turned). This has the effect of either tightening or loosening the chain, so turn this screw noting whether the chain is tightening or becoming loose.
You must slightly undo those 2 main nuts on the side of the chain/bar cover first or the bar will not move and the chain cannot be loosened.
Jul 08, 2009 | Husqvarna Garden
Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Jun 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Replacing the oil pump on a Husky 136/142 chainsaw. have you any manuals or can you tell me how to do it thanks john
Go to husqvarna.com then united states then homeowners then chain saws then manuals and parts then type in model no.
Apr 06, 2009 | Husqvarna Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
263 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
