Question about Connex Radio Communications
The modulation is weak but it keys up fine - Connex Radio Communications
    Genius:
  • 1,274 Answers
Hi,my name is John. Try to turn your MIC GAIN to MAX, and see what happens. Let me know if you need further help.....hope this was helpful.....Rate this solution on the four thumbs-up.......John
Posted on Sep 08, 2010
186 red motor. Why does it have a missfire under load?
Engine is under max load in the situations you describe, so any weakness in spark or low fuel prssure can cause this, even a weak ignition module.
Aug 11, 2015 | Holden Cars & Trucks
How do i fix a code po688? 2004 pacifica, no crank, no start, dash lights are on with key on the on position
Weak battery- Low voltage while cranking
- Faulty Engine Control Module (ECM) relay
- Blown ECM fuse
- Faulty ECM
- ECM harness is open or shorted
- ECM circuit poor electrical connection
Jan 20, 2015 | 2004 Chrysler Pacifica
What is code p1340 a 2002 Isuzu rodeo
1st google hit, ever google?
http://engine-codes.com/p1340_isuzu.html
the Ion Sensing module senses all 6 COP coils.
for weak spark.
you are not getting other DTC errors??? this is key.
1340 means it sees errors. this module. with a real scan tool
you can see all factory codes.
what id do , is the tuneup, why try find out why high voltage
spark is weak , before a tuneup>
spark plugs top list. no lie.
$2.49 each,
1st google hit and good.
read post 2
http://www.automotiveforums.com/t223406-obd_ii_scan_code_p1340__what_is_it_.html
google really is your friend, for sure.
finding isuzu books is no fun
so use alldata.com.
Jul 04, 2014 | 2002 Isuzu Rodeo
Wont start without starter fluid
it is the ignition module or a failed coil . It the spark is faster than cranking speed then it is most likely the module.
Apr 22, 2014 | 1994 Ford Ranger Supercab
At times my 2011 seinna willnot crank. the dash video will say that it does not recognise my key. then after a number of tries it will crank. my toyota dealer could find no problem.
Do you have any issues with your other key? There is a small RF transponder in your key that is transmitted to a module in your vehicle. When the module identifies a valid signal it will allow the vehicle to start. What happening is that your vehicle isn't identifying the key because the transponder signal is weak. I would speak to someone at the service department at the dealership where you purchased the vehicle and have them cut and program you a new key to replace your defective one.
May 27, 2011 | 2011 Toyota Sienna
Engine was running fine,i parked it ,when i restarted it the engine was skipping ,backfiring,won't idle sounds like timing is way off
Ignition module,faulty or ignition switch contacts bad ,try turning key a bit farther on or clockwise ,not too far,might inergize starter check for weak spark at the plugs.
Sep 10, 2010 | 1992 Oldsmobile Achieva
Starts fine when cold. If I turn off, pull key out, then put key in and crank it just weakly cranks but will not turn the engine over. Let the car sit for a while (an hour or so) and it will start fine. ...
could be the starter armature. when warm requires more amps. could also be weak battery. local auto parts store can load test the battery, usually for free
Sep 04, 2010 | Honda Odyssey Cars & Trucks
I have a 1995 Mercedes-Benz S320. I turn the key to start car it starts then dies. Try to start it again but won't start. Battery is fine. What are the possible problems?
It dies after start since not having fuel. There are several factors needed to be checked:
1-Fuel injectors got clogged up or injector module control is having a problem.
2- Not having correct fuel pressure due to fuel filter gets clogged up.
3- Fuel pump is weak not delivering correct rate per spec.
Aug 17, 2010 | Mercedes-Benz S-Class Cars & Trucks
Merces Benz s500, Ignition key does not turn, can
Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
Oct 20, 2009 | 2003 Mercedes-Benz C-Class
Craftsman mower will start with pull but not with
When it turns over, is it somewhat sluggish (not as fast as before)? I would suspect your battery is weak, and the voltage drops so low that the engine does not spin fast enough to start. Also, without knowing what type mower this is (which model) it could be the voltage drops too low to generate spark (if equipped with an ignition module)
Whereby pull starting it, you aren't loading the voltage down with the starter, and the ignition module still works... So it starts.
Charge the battery per the owners manual. If that doesn't help, you may need a new battery, or you may have a bad connection between the battery and starter solenoid (heavy cables). If a connection has high resistance, it will drop more voltage at a given current.
Jul 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Radio Communications Logo
57 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
