I have a nissan x-trail.it failed its nct for parking brake imbalance.its reading was 59% and it needs to be below 50% to pass.i checked back pads and discs and they are all fine and the cable is adjusted good as well.what can i do to get my parking brake imbalance better?
  • 1,675 Answers
Hi this sounds like it require lubrication at the joints rather than trying to get it equal if as you say everything is ok just not pulling up evenly, you need to remove the rear rotors and copper slip/copper ease the areas that touch the back plate, copper slip/ease the joints where the cable connects to the leaver for the shoes, put some grease on the joints where the cable splits to either side, and the cable itself and that should do it...hope this helps
Posted on Sep 07, 2010
HOW TO RENEW FRONT BRAKE PADS ON V REG NISSAN X TRAIL 2.2 HP
take it to a mechanic brakes need professional service so that you can be sure they will work when needed
Feb 25, 2015 | Nissan Cars & Trucks
Rear wheel clunking noise and squeeling noise sometimes
This sounds like it could either be brakes or a wheel bearing going bad. You can check this by removing the rear wheel and inspecting the brakes making sure the caliper is mounted on tightly and brake rotor isn't showing uneven wear. Also be sure to check the brake pads to make sure that they are not worn down to the squealer tabs. Most new pads are roughly 3/8" -1/2"thick. and will start squealing if at about 1/8"-1/16" thick. If everything checks out fine then check the wheel bearing by simply jacking the wheel up off the ground and grabbing. Now try to move it side to side or up and down, it should have no play what so ever. And spin the wheel to listen for screeching or squealing, it should rotate smoothly with no abnormal noises.
Apr 17, 2014 | 2005 Renault Laguna 1.8
Rear axle offside imbalance
I change one time a metering valve on rear of engine it was y like valve dont remenber what kind of car
Apr 10, 2014 | 1998 Toyota Corolla
Failed parking brake
a frozen shoe actuator is the most common problem; a poorly adjusted system is the second most common cause. you say that you replaced pads; did you remove the disks? your parking brake is inside the disks and it uses shoes, not pads.
Mar 14, 2013 | 2002 Jeep Grand Cherokee
Front disc brake squeak when turning left
your last sentence is probably the reason for your squeeking brake....both the front and back of the pad need to be fitting snugly, not loose and for sure not at an angle. hope this helps
Jul 13, 2012 | 2006 Nissan X-Trail 2.2
My dash lights come on when my brakes are pushed in my 93 nissan pick-up
If you mean the brake warning light on the dash is coming on, it is telling you that you have a problem with your hydraulic system, There is a switch that senses an imbalance between the front and the rear brakes. First check your brake fluid, if it's low than you have a external leak. If it's not low, the master cylinder has failed internally.Lokk for brake fluid leaks behind each wheel and at the back of the master cylinder. If you can find a leak or it's not low on fluid you had a bad master cylinder.
Jan 22, 2011 | Nissan Pickup Cars & Trucks
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
Changed the rear brake pads on nissan x trail 2002 model. Now the brakes klick as there applied?
You can get this problem if you use cheap brake pads that do not come with an anti rattle clip set. I would never recommend using metallic pads on any vehicle, although there are some good ones out there. I would recommend using only a full ceramic pad each and everytime you replace your pads.
Dec 11, 2009 | Nissan NX Cars & Trucks
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
