Question about Singer 3116 Simple
My singer simple will only sew in reverse. Worked perfectly for 2 days of sewing. Today after winding a new bobbin and rethreading it will not sew forward only reverse.
  • 1,675 Answers
Just a matter of interest have you accidently moved the reverse sewing leaver ? you may have put it in reveres sew ? this might be an obvious thing but could be the problem its the leaver as you look from the front ie from the needle end, its the lever on the right top, move this and see if that helps.....if not just move it back and forth till it works correctly...hope this helps
Posted on Sep 07, 2010
Problem when powered on it beeps and won't sew you singer won't sew and it beeps when powered on singer quantum 9910
Try the Troubleshooting section of your manual:
Singer 9920 Instruction Manual Helpful Hints
Check that the machine is not set to wind a bobbin.
Remove all the thread and rethread from the beginning.
Mar 25, 2017 | Singer Quantum 9910 Computerized Sewing...
2001 Touch Tronic. Worked fine yesterday. Today, why can't I wind a bobbin?
If you haven't cleaned and oiled your machine recently, you might start there. Consult your owner's manual, use ONLY fresh, good quality sewing machine oil, and apply 1-2 drops of oil each spot specified in the manual.
If the machine bobbin winder is still not working, does it still sew? If so, you probably have two choices:
1) Take it in for service
2) Buy a standalone bobbin winder (~$30) from JoAnn's, Hancocks, or Amazon.com
If the machine does not sew, take it for service.
Dec 28, 2015 | Singer Sewing Machines
Singer 2263 will not sew because bobbin thread winds back around the bobbin
have you tried changing the needle?
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin case & also wound correctly
May 14, 2012 | Singer 2263 Mechanical Sewing Machine
I sewed a few days ago, put my singer machine away and today when I was ready to sew, it will sew backward, but the needle won't go down into the bobbin to sew forward.
Try the old hair dryer trick, take off the cover, pay attention where the screws go, put some gloves on, then work the reverse lever, button or whatever you have on your machine and your stitch length dial. It may have old grease or oil that needs to soften. Now put your machine back together. Clean and Oil your machine as per your manual. Try rethreading and a new needle before you sew. If you don't have your manual, go to www.singerco.com and under customer support and download one for free. Good luck. I hope that I have helped you, my advice is free.
Nov 02, 2010 | Singer 1725
The needle on my sewing machine will not move up and down, the handwheel is a little tight and the bobbin winder wont move, how do I fix this?
You are jammed up with thread or material. Clean it out, rethread, wind a new bobbin. Oil your machine and put in a new needle. When you sew, hold the thread ends when you first start out sewing for about 4-5 stitches. Read your manual, watch your dvd on instructions
Oct 21, 2010 | Singer 3116 Simple
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
My sewing machine bobbin won't spin to rethread the bobbin.
is the area free from any dust or threads? when was the last time you had oiled your machine?
May 12, 2009 | Sewing Machines
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 3116 Simple Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
