Question about Apple iPhone Smartphone
My new, two week old, iPhone 4 keeps presenting a notice "This accessory is not optimized for this phone". Forums says this is due to dust, some to liquids and some to bugs. I've tried resetting it from iTunes, restarted the phone and blown air into the charging dock. Please help me!
  • hansson_chri Sep 08, 2010
    I wanna know answers to why it happens; not just turn it in and get a new one. Sorry, am a geek in that way.
    President:
  • 3,278 Answers
Hello.
Since your iPhone 4 is 2 weeks old and you know that the problem is not due to dust, liquids or bugs, return it for a replacement.
You should not be experiencing any problems this early.
Hope this helps.
Posted on Sep 07, 2010
  • NinaE Sep 08, 2010
    Oh, sorry. Most pople want a solution ... From all that I'm reading, it has to do with moisture or dust. Do you have a screen protector ? That apparently can cause problems, also. Any changes to your iPhone at all before you received the error ?
    pople = people
  • Apple Master
  • 4,737 Answers
It's no so clear when you get that message. There are two types, one when the earpiece (headset) is connected and another even without connecting anything.
If your case is the first one, then it will need some service including cleaning the interfaces both outside and inside, means you need to disassemble the unit.
If the message displays with out without headset or usb cable, then there's must be something wrong with the usb interface, first check the connectors (small pins) very carefully and verify that there's not twisted or bent pins among them, if so try your best to straighten them/it.
Now, for both, turn off the phone, remove the battery and sim card (remove the memory card if there's one), and take a soft brush dipped in alcohol/acetone/spirit clean all the contacts (tiny copper pins) may be internal or external whatever your eyes can catch. Clean them carefully, and leave them to dry, after you are sure that it's dried, reinstall/reinsert whatever you've removed and switch On again. If the problem does persists, I would suggest you to get it done from a Service Center, otherwise you may make mistakes and might damage it permanently. You'll need to disassemble it and check the continuity or short circuit inside.
It's also possible that there's software issue, but this is only possibility, i would suspect the hardware, if you got another spare (headset or usb cable), try with it, you may at least could find out what's the cause.
As mentioned above, it could also be the Headset or the usb cable, so you need to try with another headset or usb cable.
Since taking apart an Iphone is not easy and simple, I would highly recommend you to take it to a Service Center or mobile repairing center if the above tips doesn't help.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 08, 2010
My giffgaff login
I believe so--you just need to select which sim you need --if you are getting the 4 series chose the standard size and if you are getting the 5 series than chose the nano--think the new 6 is keeping the nano
Sep 01, 2014 | Apple iPhone4 4G iPhone 4
Why can I not make the BBC Radio app work on my iphone 4. It did work well for some months but now even when I have full strength signal on 3g via ee it simply hunts and will not start. Thanks Roger
(Just to be clear, this is the BBC Radio app, right? If your problem is the BBC News app, I may have a different suggestion.)
Do you have the latest version of the app? It appears that BBC Radio just updated the app a week ago on 31July2014 (Version 1.5.3), but it requires iOS 6.0 or later and is optimized for iPhone 5. I see you have an iPhone 4.
Do you have iOS 6 on your phone? And do you have the latest version of the app?
iOS 6 is supposedly completely compatible with iPhone 4s, and it is also supposedly compatible with iPhone 4 except iOS 6 on:
  • iPhone 4, does not support:
    • Siri
    • Maps flyover
    • Turn-by-turn navigation
    • FaceTime on 3G
    • Hearing aid support
So, it seems to me that this app should still work on your phone, unless you don't have the proper operating system or you haven't upgraded to the new version.
(the info below is copied and pasted for your viewing)
What's New in Version 1.5.3 FIXED - problem with automatically finding your local station
Please note that you can also choose any local station from the option beneath the dial after turning it to 'Find Local Radio'. You can even add up to 3 selected local stations to the dial using the Edit function.
Compatibility: Requires iOS 6.0 or later. Compatible with iPhone, iPad, and iPod touch. This app is optimized for iPhone 5.
Aug 06, 2014 | Apple iPhone Cell Phones
Messages disappearing on new iPhone
well okay. maybe you could log out from your old iPhone 4 then logon to your iPhone 5s with the same informations you use on your what's up from iPhone 4.
Feb 07, 2014 | Apple iPhone 5S
Download free watsapp to my iphone4
Not currently available in the US Apple Store. Go figure!
You can try connecting to this site with Safari from your phone:
http://www.whatsapp.com/download/
I believe its optimized for iPhone 5 however.
Apr 13, 2013 | Apple iPhone4 4G iPhone 4
Do you prepare what gift on Christmas day? Present's children like the new science and technology electronic products. Newest issue's iphone4 has been certainly too expensive, we may choose cheap...
theres lots of stuff on sale at radioshack.... just dont get angry at the sales associate/ stonewall them if they sell you on batteries..... if its on sale besides the buy 2 get to free.. grab them or buy the 4 packs for 10 and return it after 2 weeks you save a enployees job plus you get your money back returning it
Oct 17, 2011 | Apple iPhone 4 Black Smartphone
Keep gettin pop ups on my screen saying! this accessory is not optimised for this iphone you may experience difficulty noise etc as if its plugged into sumthing that doesnt support iphone~ loosing...
Sure, which ever accessory you are trying to use with your iPhone is not compatible. As Apple releases new products, many of their older accessories become not compatible with the new models. Sadly, you will most likely have to replace your old accessory so it works on this version of the iPhone.
Feb 28, 2011 | Apple iPhone 3G
This accessory is not optimized for this Iphone keeps popping up
You must be using an accessory that is not an official Apple accessory. Just dismiss the pop-up and continue using it if it functions properly.
Feb 21, 2011 | Apple iPhone 3GS Black (16 GB)
I keep getting a very annoying message saying 'this accessory is not optimized for this iphone' It comes up every 1 minute or so and doesnt go away even when I reset the software to factory settings
there is a problem with your 30 pin dock connector it seems to think there is an unauthorized accessory plugged in if your phone is under warranty contact apple to have it replaced if not find a local repair shop
Feb 04, 2011 | Apple iPhone (16 GB) Smartphone
4 weeks ago my 3g iphone went warm & switched off.I could not restart it,so took it for repair.I was told that if I paid £139,it would be repaired.The phone is less than a year old & has not...
well if it is less that year old, go to apple directly and it will be fixed for free... their manufacturer's warranty last for a year...
Oct 11, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
89 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
