Question about Whirlpool Dryers
My dryer will not heat up. model number LE9480XWW1 stock number LE9480W
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
My Kirkland dryer model # sdgs800jq2 will turn on but no heat
Recheck your model number. It is not coming up on my search but I can give you an answer regardless. The Kirkland Dryer is one of many whirlpool dryers sold under a private label so it can be sold at lower price. It works the same as most dryers. The heat cycle is regulated by 2 components other than the heating coil & timer. They are a thermal fuse to prevent fires and a thermister that turns the coils on not to exceed a predetermined temperature followed by a cool down period until it resets. So the heater is constantly turning on and off. 2 problems can happen. 1) The heater coil can burn out or 2) the exhaust can clog resulting in the dryer over heating and blowing the thermal protection fuse. If your exhaust comes out on top of the house I'd be willing to bet there's a clog just a few inches inside the exhaust outside the house. Some of these require you to cut it open to get at it. Before you do that, get an ohm meter open the dryer housing and test the fuse, thermister, and heater coil. There are numerous youtube video on how to do this seach for them on youtube. Most have to do with continuity. No continuity means the component is broke. For parts, see your local appliance store that has a parts department. Everybody stocks Whirlpool parts. And if worst comes to worst, write down you model number and go to repairclinic.com & enter your model number into their self help section for step by step instructions & video links. Good luck.
Aug 24, 2015 | Dryers
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Kenmore dryer model 97272100/ stock 72721 does not heat..replaced igniter and coils
Kenmore dryer model 72721 does not heat. Where is thermostat
Oct 08, 2010 | Kenmore Dryers
Kenmore Ultra Fabric Care dryer Model/stock number 96595220 65952 Dryer shuts off all the time. Runs, heats, works, then just stops. This happens repeatedly. Please help!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 659 Electric Dryer
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Not heating up
This looks like it is an older model. The normal place I check for parts doesn't stock the heating element. I found an alternative place but the part is $90.
The element is in the large round area that surrounds the drum assembly. Here's a diagram. The heating element is part number 512. The line doesn't reach all the way there but I think the element is the two dark rings inside the housing. Here the page with the parts listing. You'll note that the model number is the same but the brand is GE. GE makes hotpoint.
Sep 25, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
