Question about Kenmore Washing Machines
I have a front loading Kenmore Washer 417.29042991 All of a sudden it does not finish the spin cycle for the regular wash setting. It does however finish the spin cycle for the permanent press and hand washable options. I am guessing that it may be the "timer-washer" I took the top off and the timer cam part seems to work the same on all the different spin cycles for regular, permanent press and so on. Seems ok that is.
  • ponshop2 Sep 08, 2010
    I am looking at the parts blow up and the only thing i see that sounds like a "control board" is a part called a "Speed Control-AKO-Siemens mtr" It is located at the bottom of the machine. I am not seeing anything like a control board in the vicinity of the timer and knob assembly. The speed seems to be controlled correctly on the permanent press and hand wash cycles however. Is there some easy way to check out the timer? I have an ohm meter but unfortunately it is about a two hour drive from here. I guess that would be asking too much to have you tell me how to run resistance checks on this particular timer. Is there something simpler like listening for clicking noises at certain times or something?
  • Kenmore Master
  • 19,396 Answers
Hi.
The board located at the bottom of the machine is a motor control unit. The board is a module that controls volts to the variable speed motor.This is tested in full reading voltages to motor. This board is often indicated as MCU, while the main control unit is called CCU.
Before going for MCU or CCU you need to check the drain system and the pressure switch. Both parts determine the end of the cycle once the cycle is complete.
Blow in the pressure switch tube, and eventually replace it, as the part is inexpensive but difficult to test (it is tested in full by reading Ohms while tub is full).
If drain is OK, a definitive test will be done reading volts at CCU and MCU. For safety reasons, tests with power on must be done by a trained technician.
Regards.
Ginko.
Posted on Sep 08, 2010
  • 2,272 Answers
There is a control board behind the timer assembly.If timer checks ok then check the control board.Because as you mentioned that it finishes the spin cycle for the permanent press and hand washable options so the motor is not the issue.But board can be the issue if timer is checked ok.Because the board gives command to timer to start and run. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 07, 2010
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Washer does not finish spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Kenmore Elite 45986 Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine
full of sudsy soap after cycle complete, no water ???sounds as if your using the wrong detergent, youll NEED to use an HE detergent (low sudsing)specifically designed for use with front loading washers
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
