Question about Onkyo TX-SR304 Receiver
Low treble I connected TX SR304 to subwoofer with 80 mz crossover, speaker settings = small and I am getting very little treble out of my Bose speaker satellites. A speaker wires go directly to Bose bass unit; subwoofer cable goes to a Hsu.
    Problem Solver:
  • 15 Answers
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
Posted on May 15, 2008
Where can I get a set of crossovers for the Bose 601 series III
Bose don't sell a lot and indoubt you can order them at bose, i think they say: let it be repaired at a bose certified shop
Sep 18, 2014 | Audio Players & Recorders
I have Onkyo TX-SR304E receiver, it plays find on low volume, however when it is on 40 or above after some time the unit shuts off? How can I fix this problem? Regan
Check the impedance of your speakers. It sounds like the amp is getting overloaded and shutting down either for over current or over heating.
Most common issue is a partially blown speaker or crossover.
Sometimes it's just a rogue strand of wire, and reconnecting everything fixes it.
But measure the impedance on all the speakers anyways!
Feb 25, 2011 | Onkyo TX-SR304 Receiver
I have an onkyo tx-8255 receiver and i bought a psw-505 polk audio subwoofer to supplement my Boston acoustics cs-26 bookshelf speakers but i cannot get more than the deepest of bass to emit from the sub. ...
The problem is you are dealing with two different brands of speakers, I know because I ran into the same issues you are facing now, I had a Bose sub matched up with two Radio Shack Satellites and sound was not balanced it was awful. Finally I broke down and bought a pair of Bose Satellites and I have never regretted it since. The point I'am making is that when you mix brands the sound will be unpredictable, the problem with most subs is they have a very low roll off frequency even without the crossover making almost impossible to match speakers.
Feb 05, 2011 | Onkyo TX-8255 2 Channels Receiver
SUBWOOFER VOLUME PROBLEM
Make sure you have the sub connected to the proper output on the receiver and no connections are damaged.
Then check the gain/level control for the sub. on the receiver...turn it up if it's down.
Make sure that in speaker setup, that you have the selection for a sub turned on.
Jun 14, 2009 | Onkyo TX-SR304 Receiver
Woofer assistance
You need to buy an active (self-amplified) subwoofer. Attach it to the Subwoofer Preout connector.
Go into Speaker Setup (SP SYS/SETUP Button near upper right side of Op Panel) and follow the prompts.
The parameter we're most interested in is the question "Subwoofer Yes" or "No".
Some guidance when selecting speaker parameters for the rest of the channels:
SMALL vs LARGE: This has nothing to do with size so much as it deals with the BASS handling capacity of the speakers. If you say SMALL, most low frequencies from those channels will be re-routed from them to the Subwoofer. If you say LARGE the channels will still get the low frequencies they deserve.
I imagine you would be able to answer LARGE for all of your speakers.
Even if you have all LARGE speakers defined the Sub will still have work to do as it will be dealt the LFE (Low Frequency Effects) from encoded movies and all or most of the content below certain frequencies.
Mar 27, 2009 | Onkyo TX-DS575 Receiver
How can I make this sound great.
line out from mixer------to crossover in---------crossover out-------to amplifier line in-----------from amplifier out--------to loud speaker.
---from low output(low frequency)of crossover-----to line in in subwoofer.(mixer is ordinary mixer not powered mixer- and in case of powered mixer take care it is line out(0db---to4db)not amplifier out which you connect it to loudspeakers.
May 19, 2008 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Denon AVR 5803
If there is "large/small speaker" settings on your receiver, maybe you set speakers on Large. Some receivers, when set speakers to "large", won't redirect signal on subwoofer.
Oct 02, 2007 | Audio Players & Recorders
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
Onkyo TX-SR304 Receiver Logo
179 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
