Question about Refrigerators
Freezer temp appears fine - refrigerator temp is 48
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
My 12 year old subzero fridge (650) is not getting cold. this morning i discovered ice behind the fresh food drawer, removed it, it was running fine, temp 35. now tonight the temp is 51. freezer is fine....
Is it flashing vacuum condenser? Ice behind the crisper drawer shouldn't effect the temp. What is it set at? You can go to www.subzerospecialists.com and click on Tech Help for additional info.
Feb 23, 2011 | Sub-Zero 650 / O Bottom Freezer...
Freezer side not freezing
It appears that the defrost bi metal control is hanging up and during the defrost the temp in the freezer is going too high. It is supposed to terminate the defrost at around 50 degrees. This usually occurs in about 20 minutes, if the defrost heater stays on for too long the freezer temp goes too high. Change the defrost bi metal
Jan 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Traulsen URS 48 DT Freezer in Freeze/Thaw Cycle/Fridge Side O.K.
I'm not intently familiar with this particular brand, but here's some ideas to check. If the thermostat sticks on, the freezer coils can freeze, blocking air flow and jamming circulation fan. This will cause the temp in freezer compartment to rise. When the ice on the coils thaw, the compartment starts to cool again, but the cycle will continue. Another thought is if this unit has a defrost timer that could be defective. Without seeing the unit, it's hard to determine the exact cause.
Hope this helps.
Jan 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
