Question about Vacuums
Manual for case 420 skid steer - Vacuums
Swivel wheels won't stay straight and the vac just skids.
Do you find that the wheels are jammed and won't rotate, thus causing the vac to go to theleft or right or just have to be dragged along forward?Try wd40 to see if it will allow the wheels to rotate freely.
May 17, 2015 | Miele Vacuums
Bissell powerforce with bag, not picking up, but alot of suction in hose. Brushes are rotating, just not picking up.
Flip it over and unscrew the screws that hold the bottom skid to the chassis. Pull that off and check the intake to the hose. You will likely find it stopped up there.
Apr 18, 2014 | Bissell PowerForce Bagged Upright Vacuum,...
My 1 Year Old Sebo X4 was lowering itself to hardwood floor with no air gap. Sebo Support agreed with my repair shop that a new (blue) brush roller would fix the problem by replacing the 'worn" brush (same...
No not quite. For a start, the stiff bristles on the blue roller can last a few years before requiring to be replaced.
The SEBO sensor wheel adjusts to the height required - unless of course the microchip board has been tampered with. If it hasn't been tampered with. If the central wheel is excessively dirty then it could be that the SEBO isn't lowering the height properly. However, the X series is great at cleaning hard floors in general - i it is not designed for the brush roll to fully hit the floor, thus as you suggest crushing the bristles. It is designed, as you recognise quite correctly to skid across a hard floor lightly as there is a squeegee rubber strip built in at the back of the roller bar that scoops all dirt into the central vacuum path. The front plate also lends this job. You are not being conned - however check that the rubber squeegee strip has not worn away - SEBO do sell the strips and they are easy to slide into via the press release door at the side of the brush roll.
If the SEBO has died then its a possibility that there is a microchip function that gone wrong it. Some more information would be good to know here as it could be a number of things such as the cord cables coming away at the handle.
Oct 30, 2013 | Vacuums
The brush wont rotate on my windtunnel vac but it still has suction. Could this be a broken belt?
Yep - that's usually the culprit if the brush stops turning. However, pull off the skid plate (bottom panel) and make sure you haven't picked up any string or some other obstruction that's wrapped itself around the brush & stopped it from turning. Things like hair/string don't always end up in the bag/bin sometimes if they're long enough they just wrap themselves around the brush.
Jul 13, 2011 | Hoover Vacuums
Where can i get a set of wheels for my five gallon brute vaccuum?
http://www.shopvac.com/shopvac-accessories/Products/420-63-96.aspx
emailthispage.gif printthispage.gif 1" Dual Wheel Caster (Set of 4 6774200 casters with retainers) Catalog No. 420-63-96
Four (4) casters. Set of 4 Replacement Caster Wheels with retainers. This item is the replacement for the plastic, non-hooded casters shown. These casters you will receive are an upgraded dual hooded caster that are a perfect replacement but offer superior performance.
Four (4) casters. Discontinued. Order this item and we will send you an upgraded, superior dual hooded set of casters. A = 1-12/16" B = 1/4" C = 1-9/16" D = 3-7/16"
You can also look at your local Lowe's who sometimes carry a generic wheel.
Mar 07, 2011 | Shop Vac Brute 5 Gallon Bagged Canister...
The power brush does not work.. How do I get at the belt to check it
There should be tabs holding the skid plate cover in. Turn the tabs, and the cover should un-hinge.
--W/D--
Jan 21, 2011 | Electrolux Epic 3500 Vacuum
Can my sweeper be repaired economically?
If you want to try yourself the part is:  67.jpg Genuine Hoover vacuum cleaner motor
Part # 43576102
Dimension Power Drive
Fits Models: U6311-930, U6317-930, U6323-930, U6329-930.
 I believe that you can repair it if you have the patience and basic understanding on how it works.
Oct 29, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
503 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
