Question about Pride Health & Beauty
My batteries are struggling to charge do i need new ones
  • 692 Answers
Harold Do you mean that they won't fully charge or won't charge at all. If you have the small 12/12 batteries then they do not last as long as the U1 batteries (bigger) If you have the U1 batteries check the voltage of the batteries with a volt meter Fully charged should read over 12 volts and up to 13.5 volts. Also check your charger to make sure that it is charging with a voltmeter you can measure the voltage aith the charger plugged in and you should be reading over 13 volts on each battery. Hope this helps you
Posted on Sep 07, 2010
I have installed a new battery. impeller shaft is removed. I have removed the spark plugs. The engine turns over really good. With the plugs installed the engine struggles to turn over.
As you say 'impeller', I reckon this is a boat engine? Number one tip,
Year, make model horsepower
It is normal for the engine to turn slower with plugs in as you have the compression of air in the cylinders with the plugs in. Having said that, it should still turn fast. It may be the starter is losing power or the connections between the battery and the starter are corroded or dirty. One final thing is that you should always charge a new battery on a battery charger before you install it. If the battery is not FULLY charged, it is almost impossible for it to get full using the engine. You are basically just topping up.
Mar 14, 2018 | Boating
My Thomas 6v Ride -On Train works, but VERY slow. It sounds like its really struggling to go. I have TWO fully charged batteries so I know its not the battery. Everything else on it works great...
It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
Sep 23, 2013 | Peg Perego Gaucho Superpower
Battery spark at terminals
ok, first check you battery is actually maintain a good charge while your cranking the engine. If voltage drops below 10v your battery (Although appears fine while sitting) May not be any good when current is being drawn from it.
Its quite normal to see a small spark when connecting up a battery with voltage in it. If there were a short at the battery terminals you'd be blowing 30amp main fuse all day long.
Next if you replaced starter motor was it a new one?? If not then you may want to check the brushes inside are not worn away. Before doing that though try running a direct 12v straight into the starter motor to see if it cranks bike correctly.
Jan 15, 2018 | 2000 Honda VTR 1000 F Firestorm
High revs when heating switched on.
Hi
sounds like one of 4 things
1 weak battery
2 altenator struggling to charge, may be faulty or 3 the belt may be loose and need adjusting
4 poor earth from the car battery to the car body, thats the black or brown wire, check the earth is secure to the cars body.
Regards
Dan
Dec 30, 2010 | Chrysler Voyager Cars & Trucks
Murray riding mower
You may have to change the magneto.
That's the return circuit which charges the battery.
Jul 26, 2009 | Garden
Bikes hard to start
Disconnect the alarm, give the battery a full charge and see if it manages to hold the charge. If not, measure the current flow through one of the battery terminals. Should only be one or two milliamps..!
Apr 20, 2009 | 1990 Honda CBR 1000 F
What to do
If the battery no longer holds a charge, then it sounds like you need to get a new battery, or at least have your current battery checked by a Battery Shop. Stator could be a problem, in which case you should be able to get a new aftermarket one for your bike. Just as a thought though, did you check your fuel level when it died on you? it's happened to me before, where I'm looking all over for what's wrong, thinking the bike has a terminal problem, when it just turns out that it was out of gas.
Nov 10, 2008 | 1986 Yamaha FZ 750 AE (U.S.)
I think my battery
with key out of ignition, open hood. remove clamp that holds battery in place, set aside. take off positive battery cable first (red one) then negative (black) . replace w/ new battery install negative cable first then positive. hope this help[s. you can check to see if your alternating is charging by taking off the positive battery cable while you car is running and in park or nuetral and the emergency brake on. off it runs when cable is removed alternator is goo if it dies. then altenator is not charging. don't try this if your not that exp. metal on metal could cause a short. hope this helps
Oct 28, 2008 | 1996 Saturn SL
Health & Beauty Logo
289 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
