Question about RCA HD61W66 61" Projection HDTV
RCA HD61W66 61" Big Screen TV
I'm seeing a rainbow color slanting across the top of my tv. Can you tell me what my problem might be.
  • 1 more comment
  • glzr5 Aug 24, 2008
    convergence is out, cannot adjust, do i need the changed the convergence module
  • jdt66 Nov 27, 2008
    same thang cant adjust looking for codes so you can get in with remote to do a 160 pin pont adj
  • sasha_and_mo Feb 12, 2009
    I have the same problem and the screen is curved.... i dont know why or how this happened
  • RCA Master
  • 8,457 Answers
Ur convergence it dead.U know how to solder?Tries these websites.Tv Repair World,Shopjimmy.com or Partstore.com.Buy the convergence kit for ur tv brand & model,and replace the parts in it.
Posted on Sep 15, 2009
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
I see rainbow on my color screen tv rca model r52wh74 color issues.
The problem of your tv is the convergence try to adjust it manually in the setting of your tv. If still same or no effect the convergence IC is already defective. You can find it inside your tv it is connected to a large aluminum called the heat sink it has a marking of stk- followed with a number.Try to replace it.
Jun 07, 2011 | RCA R52WH73 Projection Television
Fixing RCA TV Model R52WM24YX61 with rainbows
The ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com should solve that issue. Instructions are included.
May 07, 2010 | RCA R52WM24 52" HDTV Projection Television
Double screen and rainbow like colors
my media player does not play occur eror in error show capture video failed, show no sound device or show input is failed
Feb 27, 2010 | RCA Televison & Video
Dropped my TV :( Now all I see is a RAINBOW of colors...
sorry your tv is distroyed
you need a new screen
this happen to me
wave of colors that won't go away
May 27, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Swirling colors unwatchable screen RCA rear projection 52"
I will assume it does this no matter what the input is, It sounds like the board that controls the projection lamps is causing them to misfire? Or light up out of order in rapid succesion? you will probably need to have the TV serviced, or at least an estimate, so you canfigure out exactly what part has gone bad,( hard to tell sometimes when were not there), but be carefull if you decide to service it yourself.
Apr 12, 2009 | RCA P52926 52" Rear Projection Television
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
I dropped my 27in phillps magnavox
if this is a distorted kind of rainbow aura affecting the colour, you need to de-gauss the screen - a good tv repair man will have the mains powered magnet to fix this - and shouldn't charge alot.
Feb 23, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
RCA HD61W66 61" Projection HDTV Logo
262 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
