posted by megavolt512 on May 14, 2008
This vacuum worked fine for a year. Now it's a few months past the warranty and a strange phenomenon occurs.
When you turn it on (either via an outlet or with the direct switch on the unit) it cycles on and off every second or so. All 5 lights flash in unison with the cycling.
The suction (when it runs) is strong. The bag is installed correctly and almost empty. The front door and lower bag compartment are shut and making a tight seal. I can't find any blockages (input or output). I suspected the bag-full switch. There are two tubes that appear to go up to what looks like a differential pressure switch - I assume this senses a full bag. I don't see any blockages in those tubes.
This is drying me crazy! Any ideas anyone?
This Problem Also Relates To:
Black & Decker CHV9600 Handheld Vacuum
Bosch BSG81215UC Beetle Dual Tech Bagged Canister Vacuum
Electrolux EL7055A Bagless Canister Vacuum
Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum
Kenmore 35912 / 35913 Progressive Upright Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum
Kenmore 22812 Bagged Canister Vacuum
Can you Help with these Vacuums problems?
Hoover SteamVac F5914-900 SpinScrub Upright...
Clean water coming out of sides
I have an OLD Hoover SteamVac... Answer This...
Repair Service
Find Vacuum Repairman Near You:
