Question about Garmin GPS
My Garmin Nuvi GPS keeps flashing "Garmin" with or without the power cable plugged in. I cannot get it out of this mode (can't even turn it off). What is wrong and how do i fix it?
  • bill_tincup Sep 08, 2010
    I tried downloading the recommended webupdate software, but I had to hold the power button on for the unit to communicate. Then it said I had the latest version already installed. My GPS unit just continues to flash "Garmin" on and off. What is the problem?
  • 10,865 Answers
Hello. Carefully lift off the thin frame around the screen using your finger nail to gently pry it up. Under that frame you will see a reset button. Push that button and you will reset the device. Generally this will solve the problem. If it does, great. If not, your only choice is to send it in to Garmin for a repair or replace it. J.
Posted on Sep 08, 2010
  • 17,970 Answers
Its possible that any operating system corruption. The software files on the GPS is corrupt. Do a firmware update and problem will be solved.
To update the software, connect your satnav to your computer, download and install webupdater from www8.garmin.com/support if you haven't already done so. When it's installed it will search for updates. Follow the guide.
Good luck.
Posted on Sep 07, 2010
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
When I turn on the unit the word Garmin keeps flashing over and over, won't start up.
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck...
Nov 13, 2011 | Garmin nuvi 1350 Car GPS Receiver
My garmin nuvi 255W does not start when I turn on the car
Does the nuvi power on without being connected to the vehicle power cable? If not, first place to look would be to check the vehicle power cable for power being supplied to the nuvi. The led indicator on the power cable that plugs into the vehicle port should be lit up. If it does not light up, the fuse may need to be replaced in the plug.
The power outlet on the vehicle should also be check to be sure that it is supplying power.
Sep 04, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
When i turn the power on it just keeps flashing Garmin.
You can try three things to try and get the Nuvi to start normally:
1) soft reset: Press the power-on button for at least 20 seconds - starting from power off. It should restart.
2) master reset: This will revert to factory defaults erasing all POI's, Favourites, Tracks, Routes etc. From power-off hold the lower right corner for at least 20 seconds while pressing the power-on button once. A question should appear to erase all user data. Press yes and it will revert to factory defaults.
3) Connect a USB cable in power off. Connect it to a PC / Mac which is also powered down. Start the PC/MAC - the Garmin Nuvi should start in communication mode. Connect to the internet and load MyGarmin.com and try to update the software version to the latest one (if available). If necessary install the Garmin communication plug-in in the webbrowser.
Jul 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
When i power it on on battery power it opens showing the Garmin sign and after 5 seconds flashes off and them back on and keeps cycling. When I plug it into DC power and my computer it will power up and...
A file might have corrupted on the system.
If you uploaded some POI file just before the crash, it might be a defective POI database. You can delete it by booting in test mode (turn device off, press on the lower left corner, keeping pressed turn the device on, wait for the test menu to appear. If the unit stays on, you can connect it to a computer and see its memory, locating the poi.gpi file in the POI folder. Move it on your computer (just to have a backup; one never knows), safely remove and disconnect the USB device from the PC and power cycle the Nuvi).
Assuming it's not the POI, you will have to perform the Firmware Restore on your device (or you might install the newest firmware from Garmin, as well). When in Test Mode (see above), the Garmin Web Updater function should work: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Also, you may try a Master Reset:
http://www.gpsdiscussion.com/garmin-gps/2183-your-nuvi-having-trouble-picking-up-signal-acting-lethargic-do-master-reset.htm
Nov 10, 2010 | Garmin nuvi 260W GPS Receiver
Why doesn't my Garmin 765t work without being plug
Hello:
Try first new battery .If that didn't solve the problem ,then I recommend you to reset your GPS device .
To reset your device please follow these steps :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 17, 2010 | Garmin nuvi 765T GPS Receiver
Garmin nuvi 660 in PC Sync mode even it is not connected to PC USB or AC power supply. So the GPS is useless since it is not even in navigation mode. Any idea how to solve it?
Here's a work around. 1) Plug the USB cable in and let enter Sync Mode as usual. 2) When the Garmin unit is in Sync mode, unplug the USB cable. 3) The Garmin unit will start to exit Sync mode, at which time, IMMEDIATELY plug the USB cable in again. 4) If you plugged in the USB cable in time, notice the Garmin unit will remain out of the sync mode.
Jul 04, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
GPS Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
