Question about Brother HL-2040 Laser Printer
DRUM LIGHT KEEPS FLASHING - Brother HL-2040 Laser Printer
The drum light is keeping flash what can i do to solve that problem?
Posted on Oct 30, 2010
I've replaced the toner and drum. Now the drum light keeps flashing. How do I reset it?
Try this
After replacing the drum unit, keep the front cover open (make sure the power is on).Press and hold the “GO” button until all four LED’s are lit.Once the four LED’s light up, close the front cover.Make sure the drum LED is off.The counter is reset!
Aug 11, 2010 | Brother HL 5150D Laser Printer
Hi, the drum light keeps flashing on my printer and won't print. I purchased a new drum and this fixed the problem for two weeks but now it is flashing agian, how can I sort this? thanks
Try this.
  • Take out the drum and toner.
  • Slid the tab on the top right from right to left 20 times.
  • Reinstall the drum and toner.
This should do it.
Jun 22, 2010 | Brother HL-2040 Laser Printer
Drum light keeps flashing wont print
check if the DRUM are correctly installed, if are ok, consider replace it cuz the drum has and internal quartz bulb for heat up and sometimes they blew
Feb 26, 2010 | Brother HL-2030 Laser Printer
Brother HL5250DN PRINTER THE DRUM LIGHT KEEPS ON
it has a drum sensor ,it was disable to work but it look like new please change ot replace drum unite not only drum total unite then solve your problem
thanks Tareq
Nov 11, 2009 | Brother HL 5250DN Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
Drum light will not go off
Open front cover of the printer, Press and hold down the GO button until all the LEDs light up, once all are lit release to GO button
Mar 18, 2009 | Brother HL 5250DN Laser Printer
Drum replaced light keeps flashing
When the print quality deteriorates and the drum light is flashing you can replace teh drum but the light will continue to flash until you reset it. Do this by opening the front of the printer and holding down the Go button for about 4 seconds until all four lights on the display are illuminated. It should be fine after that.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brother HL-2040 Laser Printer Logo
321 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
