Question about Kodak EASYSHARE Z1485 IS Digital Camera
I have a kodak Z1485 IS, i have changed the batteries and it still doesnt want to work. When it turn it on the blue light flashes & then the lense comes out and gets stuck. I even tried to plug it into my computer & a green light kept flashing. I have just tried to turn it on again and now the blue light comes on then goes straight off and nothing else.
I had a similar problem. Make sure you are using the type of battery specified by the manufacturer. I was using alkaline batteries, switched to the type of battery shown on the battery cover and my camera works great.
Posted on Sep 19, 2010
I was looking through some box's and i found this camera. i put in two regular AA batteries and it worked fine, now its not even turning on. I tried changing the batteries.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 13, 2015 | Kodak EASYSHARE Z1485 IS Digital Camera
I can not turn it on....i try putting in batteries CONSTANTLY and it last for about 30 minutes....at the most. now, it doesnt turn on at all...VERY frustated.
I have the same problem. I called Kodak and they told me it can only work with lithum batteries. Suggested that I use CVR-3 batteries. I am trying that now and will let you know how it works.
Jun 24, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
I'm going through batteries like crazy. Is there a recharger anyone can recommend for the EASYSHARE Z1485 (crv3 3v)
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
NB: You are using the correct battery pack.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 20, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Hi my daughters camera only worked for a month now it will not turn on we have replaced batteries several times with proper batteries recomended. PLEASE HELP!
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
3. Without the memory card,turn on your camera.
If problem still persists. There is a 28 days return garantee from the shop. If the sales date have past this you can arrange a repair:
Contact KODAK:
Nov 20, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Wont turn on anymore. shutter goes in and out and screen wont turn on
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 04, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Lcd screen cracked on kodak Z1485 camera
Google the words...disassemble a digital camera.
Sep 05, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Hi i seem to have problem with my kodak z1485 IS, the lenson the camera doesn't seem to extend or retract as a result of which it has extended fully and is now stuck there, and the camera doesn't work at...
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 24, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
My battery life is so short on my new Kodak easyshare Z1485 IS. Which battery will give me the greatest number of shorts? Does greater megapixel use more battery?
The Z1485 requires 3.7 volts to operate properly. You will not get more than 3 volts with standard AA batteries, and worse yet with NiMH rechargeable batteries which only put out 2.4 volts. You should purchase KLIC-8000 Lithium Ion rechargeable batteries and the special charger.
Jun 19, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Kodak EASYSHARE Z1485 IS Digital Camera Logo
146 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
