Question about Brother LS-2125 Mechanical Sewing Machine
The thread doesn't complete its' trip around the bobbin causing it to jam and in general not sew a darn thing.
    Genius:
  • 1,788 Answers
Refer to your manual, you may have it not threaded right, your needle is inserted backwards, bent needle, it could be any of these problems. Go to Brother's website at brother-usa.com
Posted on Sep 08, 2010
Bottom feed stopped working, won't advance fabric, stopped all of a sudden
could you maybe while changing a bobbin or somehow , hit the Darning button its right next to the Bobbin release , a machine in darning mode wont advance the fabric and the traction feet go down to level with the platen (sign that it's in darning mode)
Aug 13, 2015 | Sewing Machines
Bobbin thread not being picked up Necchi 7010
This is a tough fix. There is a metal ring with a hook on it that goes around the bobbin. Check that there are no threads jamming the bobbin parts. Short of that, sry its a trip to the repair shop.
Nov 18, 2014 | Necchi Sewing Machines
Bobbin thread gets jammed
Is it forming a stitch at all? Do you have your needle set properly and are you certain it is the correct size. it sounds like the hook isn't catching the loop formed by the needle. If changing the needle doesn't help. it might be time for a clean and adjust.
Dec 14, 2012 | Kenmore Sewing Machines
It doesn't cry when the bobbin is out
the thread jam could have done something to a sensor or could
have caused a problem with the computer motherboard.
Dec 03, 2012 | Sewing Machines
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
I tried to change the position of the zipper foot and ended up breaking the needle and now the bobbin thread keeps snapping when I try to sew. What should I do to fix this problem?
There could be a couple of general reasons for this to happen.
First, the tension in the bobbin holder could have tightened when you were trying to fix the needle. I don't explain them, I just know strange things happen when you try to fix one thing.
Secondly, I can't tell how old your machine it, but I know that the mechanism that holds the bobbin holder can become jammed and the thread wound around it. That too will cause the bobbin to not feed properly. You need to be sure the area around the bobbin holder is clear of all threads.
How did you try to change the position of the zipper foot? Did you just change the needle position and move the foot to the other side or did you do something else? I'd need to have more information to tell you anything more specific.
Nov 28, 2010 | Kenmore Sewing Machines
My machine wont pick up the bobbin thread, and when it does, and I start sewing, it keeps jamming, and the thread locks around the bobbin spindle. It keeps sewing in one spot, which I have to cut the...
check that the bobbin thread is pulled thru 'the tongue' of the bobbin case: that is what controls general tension of the lower thread. also make sure the upper thread is threaded thru the tension disk and the disk is 'grabbing it'.
Feb 02, 2010 | Sewing Machines
Thread jamming up around the bobbin
Sounds like your bobbin wasn't wound tight enough. Try winding another bobbin and see if that helps
Apr 20, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
The thread jams in the bobbin well
Make sure that you are using the correct bobbins and you have put the bobbin the right way around, make sure that you have threaded the machine correctly, and the needle is around the right way, these are a few things you can check.These are just a few simple things that a lot of inexerience sewers could check before going to a technician.
Jan 14, 2009 | Kenmore 15616
Threading this machine.???
It really sounds like you have it threaded wrongly. You should find threading instructions in that manual.
Oct 23, 2008 | Euro-Pro 1100
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
