Question about Yamaha Music
I have a hardly used Yamaha p90. I get very little sound from the speakers esp. the left one. I sprayed the volume switch with de-ox-it? as suggested but now have no sound at all. I took the case and switch out and see no apparant loose wires. Help!
  • Yamaha Master
  • 5,603 Answers
NEVER use de-oxit in a volume control potentiometer !!! Use it ONLY on metal switch contacts.
De-oxit will destroy the lubrication in pots and the resistance element.
You MIGHT try CRC226 which is safe to use. It is available at Home Depot in the electrical dept. Blue can, about $2.75. Make sure it is CRC226 as there are other CRC products there which are not applicable.
The volume control may be damaged now and may need replacement. They are not expensive other than the labor to install it.
Posted on Sep 07, 2010
Yamaha p90 keyboard sounds deteriorating
Does this still happen while using headphones? If so, I would suggest trying a different power adapter. If it's clean through the headphones then you may have a speaker malfunction.
Nov 03, 2016 | Yamaha Music
Yamaha ELectone FC-20 volume "control sliding switch" that control the volume of the upper &lower keys there are no sound only if I put some force on this "switch" Will this be very costly to repair?
Should run about $100. You can try just cleaning the slider your self first with cleaner spray sold at Radio Shack (ask the clerk which one). Be careful not to get the spray anywhere other than the slider track as it may react with other plastic parts. Spray a little then move the slide the full length a number of times,
Aug 11, 2016 | Yamaha Music
P90 sustain sound won't stop some times when am playing
You could have-
dirty contacts on the switch inside the pedal
dirty contacts in the jack the pedal cable plugs into
a cold/loose solder joint where the cable connects to the plug or to the switch.
If you rule those all out it's an internal problem with the pedal, which you can check by using another pedal, or it's internal to the P90, which will need to go to the shop.
Feb 25, 2015 | Yamaha Music
Check and see if there is a switch on the foot pedal. Check the P-90 menu under footswitch to make sure it is set to sustain.
Hello, I have a Yamaha P90. 4 keys are not responding. all others are ok and give sound. What happened ?
If they are the same note- different octave- it may be a bad solder joint near the main oscillator IC.
If they are the same cluster (adjacent white keys or adjacent black keys) in the octave, it may be a faulty wire connection.
Apr 01, 2012 | Yamaha P90 Digital Piano
Intermittent sound from the left speaker. Seems to clear up when I slide the volume switch up and down. I'd like to take it apart to clean the volume switch and look for possible loose wires.
If you have a SLIDING FADER CONTROL use CRC226 and spray a little bit right in the center of the slot using the little tube spout. Then work the control a bit and give it one more little squirt. Use sparingly. You can get the CRC226 at Home Depot in the electrical dept. in a small blue aerosol can for bout $2.70. use ONLY this product as CRC makes other products. Use CRC226
May 16, 2011 | Music
My yamaha psr 420 has most of the middle keys not producing any sound when pressed. The others too produce an abnormaly high sound when pressed. Please whats wrong and how do i solve this problem?
Your key contacts have gotten dirty. Two contacts per key are used to sense velocity and if one doesn't work the sound will be full velocity and loud.
The contacts are conductive rubber "pills" in silicone rubber domes that the key presses down onto circuit board traces under the keys. Clean both the "pills" and the black portion of the circuit board GENTLY using ONLY 99% isoprophyl alcohol and QTips. There is a lot of disassembly required and one has to keep track of where the screws go and length and thread type to re-assemble after cleaning. Also great care must be taken to not damage the ribbon cablles connecting the top and bottom halves of the case.
Jan 11, 2011 | Yamaha NP 30 76 Key Lightweight Digital...
I get no sound from the key board the display shows the keys being pressed all functions look like they are working but no sound at all
We can only guess what keyboard you might have. Maybe it has built in speakers or requires external speakers.
Usually on the keyboards there is a headphone jack. The jack disconnects output if headphones are in. Some keyboards have mute functions. Some use rotary volume controls, some use sliders... The controls can become damaged causing problems.
We don't have ESP to know what model you have and can give no further help without the model number. Always post as much detail and tests you have run.
Sep 13, 2010 | Yamaha Music
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
Music Logo
160 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
