SOURCE: Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
If the deck has not been altered and the blades are not altered or bent,maybe you have a soft rear wheel. stephen.
