Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
I can not set up my answering machine it just keeps on ringing Help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden 5.8GHz cordless system I can only suggest you select it from the list beginning here to download the manual.
Posted on Dec 02, 2012
  • kakima Dec 02, 2012
2 Suggested Answers
  • 1340 Answers
SOURCE: Setting number of rings before answering machine kicks in
Probably a cordless right?If it is,there should be a function button on the handset.Without pressing to dial out,press or hold down the function button.If there is a directional type button,you may have to press down or keep pressing the function button to cycle through the options.Once you find the ring set,it will probably require the directional button up or down to change the number of rings.Function could also be on the base,but it's usually on the handset.You may have to play around with a couple other buttons if there is no directional button but most seem to have the directional button these days. Good luck!
Posted on Jul 23, 2010
Testimonial: "Thank you once again for your help!!"
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
I lost the manual, how do I set the day and time, and rings to answer. It picks up after 4 rings, can I set it for more rings? Thank you
I have this answering machine...
To set the day and time press the "REPEAT" button and hold it in. It will say something like "Time not set." and if you keep holding it it will say, "Monday." Now release the "REPEAT" button and use the "ON/OFF" button to cycle through the days. When it says the correct day, press and releasethe "REPEAT" button. Then it will go on to set the clock and you're done.
To adjust the rings, there is a slide switch on the top where the cords plug in. You can switch it to 2, 4 or TS (Toll Saver). Toll Saver generally lets it ring for about 5 rings before answering.
Nov 24, 2010 | Conair TAD2018CG Digital Answering Machine
How to set the time, and longer than 5 rings to my digital
its network dependant any network will keep the line for 30 sec only for ringing
May 24, 2010 | GE 29875GE Digital Answering Machine
Not receiving faxes. Machine just keeps ringing.
Make sure fax is not set to TEL mode...it will keep ringing and never answer. It should be set to FAX. mode.
Mar 15, 2010 | Office Equipment & Supplies
My phone is set to ring only 4 times. It just
I changed the ring time and the machine started picking up my calls.
You owe me $12
Sep 30, 2009 | Uniden Lands Phones
Fax receiving problem
press the set up button or the tool button the printer . then use the right arrow or left arrow button scroll to basic fax set up ,and advance fax set up. u will find the distinctive ring pattern under advance fax setup. also check if u are using any telephone answering machine if using check the rings to answer in ur printer should be 2 rings higher than the rings to answer in the telephone answering machine.also turn off the error correction mode.turn the auto answer on.try this steps
Sep 11, 2009 | Office Equipment & Supplies
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Can not set no of rings on old sprint answer machine SP818 please help
Ring Select and Toll Saver
Use Ring Select to choose how many times the line will ring before the
system answers a call. Set for 2, 4 or Toll Saver. When you set the
system for Toll Saver, it answers after four rings when you have no new
messages, and after two rings when you have new messages.
1. Press and hold [SET UP] for about two seconds. The system announces
the current ring selection.
2. Press and release [ANN/SKIP] or [MEMO/REPEAT] until the system
announces your ring selection.
3. Press and release [PLAY/STOP] to exit
-OR-
Press and release [SET UP] to change the Remote Access Code (follow
Steps 2-5 under "Remote Access Code").
Oct 01, 2008 | Lands Phones
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
15 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
