Question about HP LaserJet 5100tn Printer
Displays a message "perform printer maintenance" What maintenance am I supposed to do?
  • 1,110 Answers
This means that the printer is due for it's scheduled maintenance. Things like paper feed rollers, separation roller, transfer roller and fusing unit are due. Now if I were you I would just ignore it as long as you are not having a lot of jamming problems or double imaging/print rubbing off issues. I have seen these HP's run way past the maintenance schedule. You will do absolutely no harm if you continue to run it. The parts that are due to be replaced will continue to wear and eventually you may have to do at least some or all of the maintenance but for now I would not worry about it at all unless like I said you are having problems. As a side note I work on HP laser printers for school districts that do not want to spend money on printers so I have seen lots of these printers with the "perform maintenance" indicators on for a year or more with no problems.
Good Luck and Thank You for using Fixya.
Posted on Sep 07, 2010
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
T632 reset count
Enter diagnostic mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when Performing Self Test displays on the operator panel.
Once you're in diagnostic mode, go to Printer Setup > Page Count.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
Jan 30, 2013 | Lexmark T632 Laser Printer
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
1. Select Reset Maintenance Count from the Configuration menu.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
I have a Dell W5210n printer that I replaced the fuser on. How do you reset this printer?
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
(answer previously provided on fixya.com by ramrui)
Jan 04, 2010 | Dell 5110cn Laser Printer
How do you reset the mainentance count on Lexmark t640 printer.
Enter the Configuration Menu:
2. Press and hold (check) and (right arrow).
4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel shortly.
5. Scroll to Reset Maintenance Count from the Configuration menu and select.
6. Press (check) to reset count.
Oct 08, 2009 | Lexmark ImageQuick SIMM (15W0000) for PC,...
How to reset maintenance counter on a Dell 5310
Jul 21, 2009 | Dell 5110cn Laser Printer
Setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Dec 17, 2008 | Lexmark T644dtn Printer
Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Aug 21, 2008 | Lexmark T644dtn Printer
Getting an display in the printer.
If you have the manual there is probably a section about this. It does sound like some parts may be wearing out and the printer is asking for new ones. Check out this link: http://www.printertechs.com/tech/maintcount.php A snip from the info there: If the display panel on your HP laserjet reads "perform printer maintenance", "perform user maintenance", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count. For example the laserjet 4000 has a 200,000 page maintenance interval. Once you reach 200,000 pages the error message appears and you need to reset the maintenance count to zero to make the message go away.
Jun 15, 2007 | HP LaseJet 4350dtn Laser Printer
HP LaserJet 5100tn Printer Logo
1,344 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
