Question about Dryers
Bosch maxx wtl 6300 dryer when placed on a dry cycle it beeps every couple of minutes and stops and the filter light flashes. The lint filter is cleaned and it still does this any help?
  • Anonymous Mar 19, 2014
    I wonder if you can help me with an issue with my Bosch Logixx max 7 sensitive tumble dryer WTE84121BY/08
    I has been working perfectly fine up until now, where about 5 mins into a cycle it stops and beeps and two of the lights flash.
    I have emptied water container, I've washed the air cooler, cleaned all the seals of fluff, empltied the fluff filter, made sure its level and it still flashes these two indicator lights and beeps.
  • Anonymous Mar 21, 2014
    lint light flashes dryer won't start
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
Bosch said I need to open the condensor part down the bottom below the door and clean it. The only problem is I don't know how to open it!
Posted on May 26, 2008
We had the same problem, and the bottom panel does open, you just have to pry it open. It was unbelievably filthy in there. We haven't had any problems since. We bought ours used and don't have an owners manual. I'm trying to figure out how to dry on anything but high heat. Any suggestions?
Posted on Jun 28, 2008
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
I have a Bosch Maxx Sensitive WTE84100AU dryer which stops a few minutes after the dryer starts. The dryness lights all turn off. The clothes don't dry.
There is a thermal overload switch behind the back cover. It has overloaded because the big lumps of lint in a) lint basket, b) small vents either side of the vent basket (use a chopstick), c) in the big pull out condenser unit at the front bottom left, and d) reach right to the slot for the condenser unit and scrape all the lint out of the back.
Now you can do the reset - unplug your dryer first. You will need a Torx T15 screwdriver to undo the all screws around the fan & drum cover, then use a thin blade to pop off the back cover. If you don't have a Torx screwdriver, you will have to buy or borrow one - there are just too many screws to use anything else.
I was thinking of drilling a 6mm hole in about the right spot so I can poke a chopstick through to press the reset button. 6607f76a-b20b-43ef-8059-a4858d51d2dd.jpg
Jan 08, 2013 | Bosch Dryers
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
May 22, 2008 | Dryers
Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
Jan 29, 2008 | Dryers
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
1,418 people viewed this question
Top Dryers Experts
