I have a gas fire grate that i installed about 25 years ago, i have recently dismantled it and would like to replace the artificle coals and the bed of sand but am having difficulty tracking down any mention of sand. can you tell me what type of sand i should be looking for. many thanks jackie
  • Heating & Co... Master
  • 3,284 Answers
Try a fire place shop where sell fire grates they should stock sand thay would work for your heater
Posted on Sep 11, 2010
  • jackielambel Sep 11, 2010
    Thanks, but have already gone down that road without any success.
  • Paul Carew Sep 12, 2010
    well you never said you had done that just asked where , google fire grate sand that should give you the name then you should find who stocks this or google the make and model if you know it but at 25 years old it might no longer be made
My gas fire has just had new coals replaced nice. Then there are large flames forcing through the gaps of the coal making loud noises as if there is a draft or air combining from some we're trying to
Paul is correct, but also check the air ajustment for the burners. If you have real large yellow flame the shutter should be opened till you get a blue flame.
Sep 03, 2014 | Heating & Cooling
Need layout plan of coals in fire bed
Rusty, to get all the coals to start burning at the same time, they are usually stacked in a pyramid shape. Once they are all hot, they can be spread out some.
Mar 22, 2011 | Heating & Cooling
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
We have a Dimplex Danesbury Dan 20 fire and need to change a bulb! How?
1.Remove the coals .
2.Remove the two screws in the front of the brass grate second bar down.
3.pull the grate assembly away from the fire.
4. The bulbs are now exposed.
Replace with 60 Watt SES clear candle bulbs. Reassemble in reverse order.
Oct 25, 2010 | Heating & Cooling
How do you condition a new grill?
Start some coals with the grate off the grill. As the coals are heating up, coat the grate in *vegetable* shortening using a paper towel. Place the grate back on the grill over the hot coals and cover. Allow the coals to burn off; this process will coat the grate with a protective layer of oil.
You might also consider running the grate through a burnoff process BEFORE curing to remove any coating the manufacturer used for protection during shipping. To do this, burn some coals for roughly 30 minutes under the grate with the lid down, let cool, then condition per previous instructions.
Jun 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Char broil patio caddie, how many coals should it contain?
Your referring to the 'LAVA ROCK' which lines the botton grate. There should be enough to cover the grate 1 layer deep only.
Apr 27, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Gas engineer wants to re-arrange coals correctly post service
yes he is right on that the postion off the coals have to be in the correct pstion to stop fire sooting and fumes coming from fire , if the coals are in postion you take them out and put them back the same as they came out , or there should be a picture of the coal lay out in the users book , or look on line for the make of fire , if the gas engneer cannot work this out then go to some one who can ,
this is basic gas fitting any gas fitter will know this if not walk away from them ,
hope this helps
Feb 05, 2009 | Cozy Heating & Cooling
Iron Grates
I had a cue cart for probably 20 years or more and I think it was the finest charcoal grill ever made. Cant believe that you can't buy them anymore. I sold it in a garage sale after my wife died in 2000. I had the same problem with the grates under the charcoal and was able to find similar ones that fit that were made for a different manufacturer. However that was some time ago as you can imagine. I would like to maybe get a local mfg. to build one but I can't remember how the mechanism worked that lifted the fire grate up and to the inside of the grill. Would it be possible for you to take a picture of that front door in the open position and send it to me. My email address is fkiss@verizon.net.
Thanks
Frank
Apr 10, 2008 | Computers & Internet
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
