FixYa.com
Tags:
Brother MFC-210C All-In-One InkJet Printer
Brother MFC-210c prints some lines blurred, letters... (by 2 users)
posted by MyCsPiTTa on May 14, 2008
I just obtained a relatively new MFC-210c with the “Unable to clean” error 46, which I solved with a new ink absorber (thanks FixYa!).
It now prints but the text is stacked or blurred on certain lines. I followed the alignment advice and, sure enough, the alignment was off so I corrected it following the instructions. Now the alignment test is good, but the blurring/stacking is still there (slightly improved). Please see images below:
http://i195.photobucket.com/albums/z141/MyCsPiTTa/Testpage003.jpg
The severity of the blurring seems to come in waves down the page, with some lines being almost fine.
http://i195.photobucket.com/albums/z141/MyCsPiTTa/Testclose.jpg
http://i195.photobucket.com/albums/z141/MyCsPiTTa/Testpagelogo.jpg
I almost wonder if it might be some problem with the timing of the paper feeding through the rollers. I dunno… any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by standleys, posted on Jun 18, 2008
same problem, scans fine, downloads photo cards but copies are blurred. like double vision
Solution #1
posted on Jul 10, 2008
Not Rated (0)
shes_absolut
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Scanning
I need help with scanning... Answer This...
replac ink
its keep saying replace... Answer This...
black ink wont work
hello thanks for your help. i... Answer This...
Using scanner function only
Trying to use the scanner... Answer This...
error printing
my printer works perfectly but... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
